Would it be a good idea to parallel a 0.1ohm resistor with the internal sense resistor(by connecting the external one in the CAP and LED pins) to double the output current? If it works, it'll make for one hell of constant-current boost IC. A simple, dimmable, 350-700ma output current boost with 1-2 cells. :naughty:
There's no mention on the specs of the internal FET's so I'm hesistant on trying it. I already ruined an IC due to the inductor coil(the insulation got nicked) shorting out with the output pin.
The IC details can be found here.
