Hi,
Thanks, I was already familar with Doug's test. I'm much more interested in the shape of the curves than the total runtime, which as you point out, is pretty easy to guesstimate. In particular, I'm curious how long the 3 led HO remains brighter than the single U- I mean, figuring out the 50% point isn't as helpful if you're not sure how 100% compares on the same scales. The ratings on the Peak site are about 43 cp for the 1U vs. about 73 cp for the 3HO.
In particular, the 3U is sucking on the batteries really hard, reaching 50% in 45 min, while the single U has a much flatter curve, reaching the same point in 3 hours, as you indicated. Therefore, the shape of the curve is obviously a function of the drain, and not a simple relationship. That is, it's reasonable to think that the 3HO might run somewhat longer than half again as long as the 3U to reach the 50% point, while remaining brighter than the 1U for a significant length of time with less wear and tear on the leds-
At the moment, it seems that the 3U will remain brighter than the 1U for about an hour, then remain about at the same output for another 5 hours or so, then the 1U pulls ahead, I'm curious how the 3HO compares with this.
Without a direct compare there isn't really a way to know how these all compare to each other when trying to pick the 'bang for the buck' camp amoug the four versions.
