remove the batteries, click the switch on, pull off the rubber switch cover, stick a 2mm allen key down the hole on the switch, loosen and slide the switch out the bottom...
technically i believe it's a 5/64th but 2mm does in-fact fit.. it's a cake walk, make sure the switch is on or it'll hang up going through and takes a lot of smaking/shacking/etc to get out.
