Lightforce 240 Blitz + 400 watt Osram HLX 64663 + 36 volt battery = 16000 lumens fun
Queenslander
Dear experimenters...
Based on other threads and best guesses, I put this configuration together yesterday for AUD$222.00 and was blown away last night with the results. It is the brightest thing I've ever seen and has a handy focusable beam.
I'll post some photos tonight - let me know what kind of shots would be most informative and how best to set exposure (digital camera).
Cost of project
AUD$145.00 Lightforce 240 blitz
AUD$ 17.00 400 watt Osram HLX 64663 bulb
AUD$ 60.00 Three 5 amp hour rechargeable batteries
+ a bit of wire and solder (free) to series up the three 12 volt batteries.
The bulb goes straight in with no modification necessary.
AUD$222.00 total cost and it rocks!!!
Total run time based on current and 5 ah battery capacity is about 25 minutes. It draws about 11 amps (400 watts divided by 36 volts = 11 amps)
WARNING - I guess it may all melt to pieces if left on for a really long time - I experienced no problems with five or ten minute run times though!
Lucky USA members can buy the lamps for even less here:
http://www.bulbconnection.com/ViewItem/bcrw/itmid/142/oc/64663%20HLX/item.html
Next project = the 24 volt 600 watt aircraft landing light torch - I think it's called a LarryK12
Re: Lightforce 240 Blitz + 400 watt Osram HLX 64663 + 36 volt battery = 16000 lumens fun
Hey, got any picutres of the end prod?
Yeah - I got one of those to mod or leave original - I'm mostly worried about melting the reflector.
You got no blisters or lumps from 10 minutes continuous use?
If they produced a metal reflector for this unit I'd be a very happy boy.
Oh, QLDer, are you using SLA batteries?
Hey Pila Power
Using sealed Lead Acid batteries... no damage to the reflector or cover after 10 minute run time - ambient temperature about 15 degrees celcius.
It's 3pm in the afternoon now... will take plenty of photos after dark (any hints).
gk
I mean "celsius"
NAW said:
Probably similar if not the same based on speculation... the above thread led me to the 400 watt globe I used!
Notwithstanding the necessary disclaimers to protect themselves in case emulators run into trouble, why don't these guys come forward with their prototype specs in addition to their shootout pictures?
It's just light after all.
P.S. I did say WARNING - my light may melt down etc (consider that as my disclaimer).
Pre nightfall pictures
LOL...great pix! It's so funny....just no end to the increasing output projects.
Nightfall... burning down the barn! (cubby house actually)
Unfortunately, I'm clouded in tonight so the pictures are a bit hazy - still you can discern the beam pattern through the mist (900mtrs ASL).
Low voltage garden lighting (tree fern).
Good god man, will you play with your new toy in some other direction? Some of us up here in America are trying to sleep!
wow :awman:....
Photo Phantom
We've been trying to get to sleep down here for years... but that constant glow over the eastern horizon is a blinder!
Thanks for the post!
gk
Next project: Handheld 2kw arc lamp with fuel cell backpack!
