It's about one year after the first LF2 Cree XR-E was released, here's new LF2X in Natural HAIII finish. :thumbsup:
Manufacurer's page: http://www.liteflux.com/english/product_detail.php?act=1&index=16
English User manual: http://mountech.myweb.hinet.net/operation manual - english.pdf
Chinese User manual: http://mountech.myweb.hinet.net/operation manual - chinese.pdf
LED Cool's sales thread: http://www.cpfmarketplace.com/mp/showthread.php?t=175263
Another great review at Light-Reviews.com: http://light-reviews.com/liteflux_lf2_x/review.html
Spec. (Copied from the manufacturer site)
Now it's the picture time (Sorry for the poor quility. :faint:)
Woody gift box:
(The silver sticker is on the shrink warp)
Content: (LF2X with clip, diffuser, o-rings, lubricant, quick release cap and 80cm chain)
Unlike the previous black HAIII, the new NAT HAIII is beautiful, smooth and shining. But the color is very hard to control in natural hard anodizing process. Thus, there'll be color mis-match.
The body has 4 long grooves (slots) like LF3/4/5. But the laser engraved letter orientation is different.
One of the new enhancement of the LF2X is the multi-function tail. It consists of 1. Detachable pocket clip 2. Socket with threaded hole to attach tripod and 3. quick release cap to use with necklace or lanyard.
Pocket Clip:
Pocket Clip detached:
Threaded hole:
LF2X on tripod and also with snap on diffuser:
Quick release cap:
The cap is twisted to lock and open. Turn 180 degree to lock and another 180 degree to open:
(Left: Opened. Right: Locked)
The thread is also anodized like LF2 but the twisting feels smoother than LF2. And head knurling is one the engine part (LF2 is one the bezel), there won't be loose bezel when you switch on/off.
New detachable 2-stage switch
There're concave dots to indicate the P1 and P2 position: (one dot for P1 and two dots for P2)
Here's a quick size comparison with the LF2:
(Left to right: LF2 SSC P4/LF2X/LF2X/LF2 Cree XR-E)
With diffuser. (Diffuser for LF2X is snap on, thus it's longer)
(Left to right: LF2 SSC P4/LF2X/LF2 Cree XR-E)
Head:
===== BeamShots =====
The beam pattern of LF2X is funny. The light OP reflector has smoothed out the transit from hotspot to side spill, but the outer side spill is brighter and make the side spill like a big dark riing for short distance.
LF2X beamshot (NiMH, default P5 50% output):
(F2.8, 1/4s ISO100)
(F2.8, 1/6s ISO100)
(F2.8, 1/8s ISO100)
LF2X(L) with LF2 SSC P4 (R) beamshot (NiMH, default P5 50% output):
(F2.8, 1/4s ISO100)
(F2.8, 1/6s ISO100)
(F2.8, 1/8s ISO100)
LF2X(L) with LF2 modded Q5-WG (R) beamshot (NiMH, default P5 50% output):
(F2.8, 1/4s ISO100)
(F2.8, 1/6s ISO100)
(F2.8, 1/8s ISO100)
The hotspot is tighter than LF2 Cree XR-E.
===== Runtime =====
All runtimes are tested in my closet with beam direct point to a lux meter. (No lightbox used). Since the brightness will be different with the angle or distance, I re-scale the intensity to 0-100 scale based on the initial brightness. I don't have recording meters, the readings are taken by webcam every one minutes.
I test for default settings only. P1 for 15% output and P2 for 50% output. Also test 100% output.
I don't know what's the dimension of the milk carton that Quickbeam used? The milk carton isn't the same size here. If I know the size, I may make one to estimate the lumen output. Thanks.
The LF2X's circuit was modified to fit the high Vf of Q5. The 100% output for Alkaline/NiMH look like not regulated. I think that may be caused by the high current drain that the battery couldn't provide.
For testing of Alkaline, the battery over-discharge protection is turned OFF. For NiMH/Li-ion, it's ON.
----- Alkaline -----
The battery is Energizer E92.
----- NiMH -----
The battery is Eneloop and charged on MAHA MH-C9000.
----- Li-ion -----
The battery is LC10440 bought from AW. Charged on self-made LTC4054 charger. The starting open-circuit voltage is 4.16v
Below is 100% output runtime. (The reading was taken at 10sec interval.)
(The sharp drop near the end of LC 10440 is the low voltage warning)
I use two 10440. One is Soshine 360mAh button top 10440 and another is LC 320mAh flat top 10440. (The botton top 10440 won't fit the previous LF2.) I don't know how much current needed at 100%, but is obviously over 2C for 10440. It's not good for li-ion to continuously drain over 2C. It's not recommended.
Both start from 4.16v and cut by the over-discharging protection. The batteries were hot when take out. After rest for awhile, the open circuit voltage back to 3.85v for Soshine and 3.9v for LC 10440. The batteries still have some juice left from the rest voltage. I think the voltage sag is large and the protection triggered earily.
===== Cleaning of the switch =====
The 2-stage switch is detachable. If LF2X act strangely, it could be cleaned. The previous LF2 was glued.
First, clean the tube bare aluminium and switch contact:
If it doesn't work, following the step to detach the switch. But don't do it if you don't know what you're doing.
1. located the two notch of the switch contact:
2. Use a sharp tweezers, insert into the notch. You must also locate the underneath notches, otherwise it won't be loosed. Turn counter clockwise to screw the switch out.
3. Clean the contacts around the positive contact stick. You could also sink the switch assembily (right part in the photo, NOT THE HEAD) in alcohol to clean it.
Thanks for viewing. :wave:
- LED : CREE XR-E Q5
- 78 mm (L) x 14 mm (D)
- Made of aircraft grade aluminum
- Natural HA III Hard anodized finish
- Battery : single AAA (Alkaline,Ni-MH,Lithium) batteries
- single 10440 Li-Ion is available
- Switch : twist
- Input voltage : 0.9V ~ 5.0V
- 4 operation modes
- 6 user defined output
- 1 user adjusted output
- 4 functions
- Weight : 19g (excluding battery)
- Waterproof
- Glass lens with AR coating
- Candle mode available
- Accessories : plastic light cover,O-ring,silicon oil
- Wood gift box,quick install necklet assembly & cilp assembly
- Use Cree XR-E Q5 (Not sure about the color bin)
- Natural Type III hard anodized finish
- 3-in-1 tail (pocket clip, quick release cap. will described below)
- Snap on diffuser
Woody gift box:
Pocket Clip:
Threaded hole:
Quick release cap:
Head:
(F2.8, 1/4s ISO100)
(F2.8, 1/6s ISO100)
(F2.8, 1/8s ISO100)
(F2.8, 1/4s ISO100)
(F2.8, 1/6s ISO100)
(F2.8, 1/8s ISO100)
(F2.8, 1/4s ISO100)
(F2.8, 1/6s ISO100)
(F2.8, 1/8s ISO100)
===== Runtime =====
----- NiMH -----
----- Li-ion -----
