AlexGT
Hi all!
I was digging up old threads and found one that talks about frosting (etching) bulbs with acid to get better beam from smooth crappy reflectors and decided to give it a try.
I went to a arts and crafts store and bought Armour Etch etching cream, The 3 ounce plastic bottle has enough to frost 100's of bulbs and it costs $6 and change.
Acid is a nasty substance and great care should be taken in handling or serious injury may occur, I used eye protection and gloves in a well ventilated area. follow directions of use and use it at your own risk!
I used a Xenon/Led/CCFL light that has good throw but suffers from a bad case of rings and artifacts in the beam,
http://imageshack.us/?x=my6&myref=
To do the treatment the bulb's glass surface should be clean and free of oils and dirt, I used needle nose pliers to grab the bulb by its metal base and dip it into the etching cream all the way up to where the glass touches the metal base and rotate it and move it around so the cream gets into all the surface of the glass.
I also used a chronometer to accurately measure how much time it needs for a usable frost, some bulbs have a tougher glass and takes longer so practice with burned out bulbs of the ones you plan to use.
Light frost gives best compromise for removing artifacts and keeping good throw, I did the tests using Walmart Rayovac 3D Krypton bulbs, model KPR-103 rated at 3.6V / 0.75 amps with four rested energizer 2500 mah NiMh for a little overdrive.
now for some pics.
The bulbs
Closeup of the bulbs, same order as above, notice how the filament towers dissapear as the frosting increases
Beamshots, Stock, 30, 60 and 90 second frosted bulbs compared to a Stock E2e on the right.
Stock
30 Second on frosting cream, still some rings but way better than stock!
60 seconds on frosting cream, rings are gone! Surefire beam!
90 seconds on frosting cream, now the E2e is starting to look brighter, absolutely no artifacts or rings!
I think the 30-60 second is the best compromise, but it may take more or less time depending on the bulb glass you plan to use.
Hope you like the little review.
AlexGT
Disclaimer: I'm not responsible if you try the frosting cream and something stupid happens and you end up hurt, follow directions of use and use it at your own risk!!!
http://imageshack.us/?x=my6&myref=To do the treatment the bulb's glass surface should be clean and free of oils and dirt, I used needle nose pliers to grab the bulb by its metal base and dip it into the etching cream all the way up to where the glass touches the metal base and rotate it and move it around so the cream gets into all the surface of the glass.
now for some pics.
The bulbs
Stock
AlexGT
