Robocop
Mammoth Killer
Ok having noticed that a standard Dorcy AAA circuit was roughly the same length as a 3 D Mag LED pill I had an idea....and you all know what happened next..hehe
With a Dremel I bored out the end of a Dorcy AAA just a little to help with contact then hand sanded the diameter of the Mag LED pill. It only took a small amount of sanding and the Mag pill will slide into the end of the Dorcy.
Next I removed the crappy Dorcy reflector and replaced it with a larger reflector that also had to be sanded to fit. Power it all with a Li-Ion AAA at 4.2 volts and you have a nice little light. It is basically the same size and shape of the standard Dorcy AAA however now with a much improved output......it gets hot quick however still a very cool and easy mod.
The included beamshot is with my Dorcy mod on the left and my Fenix P1 on the right. The Fenix is using standard 123 cells however still does well.
