I get a number of questions in PM's from people trying to figure out how to use and select the proper bulb and battery combination voltage for their particular Maglite setup. I remember not too long ago how confusing all of this was, so let me do my best to give a few SIMPLE pointers. PLEASE, NO EXPERT, DETAILED INPUT OR COMMENTARY from all of those electrical engineers who sleep on superconductors!
- OK....let's use a practical example. I want to use 2 of AW's C Li-Ion cells in a 2C size STOCK Maglite to light up a WA 1111 6V bulb, using this 1D size light I bought a while ago from FiveMega. I put the bipin bulb into a gold bi-pin bulb holder I also got from FiveMega, and put that into the stock Maglite bulb holder, and tighten down the retaining ring. Next, I look at my bulb testing thread here, and click on the 1111 bulb test data here.
- I know that each of the AW C Li-Ions when charged will have about 4.15V, and two of them in series gives 8.3V. When I look down the left "Applied Volts" column, I notice that when 8.3V is applied, the bulb flashes (dies). I am now worried that my brilliant idea of using 2 x Li-Ions at 8.3V (fully charged) will kill my bulb, and I wonder if I should use a different setup. :thinking:
- However, what needs to be taken into account is the amount of resistance (to the flow of electrical current) that is related to the various parts of the flashlight, and which effectively decreases the voltage actually seen at the bulb. There is a basic law you may have heard of called Ohms Law which we will use to understand this. Ohm's Law says:
- V = I x R or Voltage (Volts) = Current (Amps) x Resistance (Ohms)
- Now to see the effect of the flashlight parts having resistance and lowering the amount of voltage delivered to the bulb, I need to get some data in 3 measurements.
- 1) With my DMM (digital multi-meter), I measure the voltage of my two C Li-Ions outside of the light, which I know are not fully charged. Touching each together, like they would be inside the light. I get a reading of 7.94 Volts. This is known as "Vbat" (battery voltage)
- 2) With light switch off, I put the Li-Ions in the light. I then put the tailcap in position, with spring touching back of Li-Ion, but do not push down and screw it on. Now I turn on my DMM with it set to measure Amps. I turn on the switch for the light while it is resting on a brick...but with the tailcap off, there is not a complete (closed) circuit, so light stays off.
Now I take my black (Neg) DMM probe and touch it to tailcap edge where there is bare aluminum just above threads. I simultaneously touch my red (Pos) DMM probe to the back edge of flashlight tube, and my light comes on because I have now closed the circuit. I read the current as 3.52 Amps. When I take away my DMM probes, the circuit is now "open" and the light turns off.
3) I now turn off the light switch, screw on the tailcap, and screw off the head so I can see the bulb in the bipin holder. I use the DMM's Pincher leads, and clip them onto each leg of the bipin inserted into the gold bipin holder.
Now I turn on the light, and get a DMM reading of 6.65 Volts. This lower Voltage reading is known as Vbulb.
- So now we have readings of
- Vbat = 7.94V
- Amps = 3.52A
- Vbulb = 6.65V
- The difference between Vbat & Vbulb is 1.29V (7.94 - 6.65), which is the voltage drop because of resistance in the light (including bulb). Now we use Ohms Law to see how much resistance is in my setup, since we know the current, and how much the voltage dropped.
1.29V = 3.52A x ??? Ohms so then solving for Ohms:
1.29V / 3.52A = 0.366 Ohms
- There are 1,000 milli-Ohms (mOhms) in 1 Ohm, we could also say that I have 366 mOhms of resistance in my setup. In effect, this resistance is both "protecting" my bulb by lowering the voltage delivered, but is also decreasing my lumen output.
- Now I know that when using fully charged Li-Ions at 8.3V, I would only see about 7V at the bulb, so it is not going to flash. Good News! But now if I want to have around 7.5V delivered to the bulb for better lumen output, then I need to do some things to reduce the resistance down to about 220 mOhms in my light setup.
8.3 Vbat - 7.5 Vbulb = 0.8 V
This smaller drop in voltage would both protect my bulb, and give me better lumen output...so I want to try and reduce my resistance to: 0.8V / 3.6A = 222 mOhms
How to reduce your resistance is another topic. :eek:This smaller drop in voltage would both protect my bulb, and give me better lumen output...so I want to try and reduce my resistance to: 0.8V / 3.6A = 222 mOhms
