aussiebuddha
- Joined
- Aug 26, 2007
- Messages
- 252
it seems that one of those affordable websites introduces a new p7 light with a copper heatsink/pill. what do you guys think?
should i take the plunge?
Thee pill seems to be solid copper in the pics.
I dont think they'll go thru the hassle of plating a alu pill with copper? would be as expensive and time consuming exercise as just using copper.
Can it even be done?
LED Tint: SXO - slightly cool white, neutral tint is SWO - not a biggie. When I compare XO to WO A-B the XO looks white, the WO looks yellow.I just noticed another model that came out, The Aurora AK-P7 5-mode. sku 12809. $62. actually has some nice specs, if they are accurate. This might seal the deal for me....
In theory twice the run time, you have doubled the watt/hours, Vf does not change. If it uses a driver it can be efficient, if it uses resistors it burns off the extra power. Either way you do get a longer run with it.:pHi all,
And about this one : TrustFire SSC P7-C 900-Lumen LED Flashlight (2*18650/17670)
as it is powered by 2 * 18650 it should be an advantage ???
JP
I just ordered one of these:
http://www.qualitychinagoods.com/2mode-lumens-4xssc-flashlightfsp7-p-982.html
They also carry these P7 lights......
http://www.qualitychinagoods.com/aurora-akp7-lumens-2mode-flashlightfsakp7-p-999.html
http://www.qualitychinagoods.com/lumens-2mode-flashlightfsp7c-p-998.html
