Videos: How to solder properly
AlexGT
Houston, Texas
Hi all!
I found some videos about how to solder using a soldering iron, and thinking it may benefit the rest of the CPF community wanted to share them.
This has general tips on what to do to make good solder joints on a PCB.
http://www.youtube.com/watch?v=3dkragEKSKI
This is a tutorial about how to solder 2 pieces of wire, I didn't like the way he flicks the solder off the tip, use the sponge instead.
http://www.youtube.com/watch?v=BLfXXRfRIzY
This one shows correct and incorrect ways to solder
http://www.youtube.com/watch?v=I_NU2ruzyc4
HTH
AlexGT
These are good, especially the one with the examples of bad joints.
With my Weller WP35 and Radioshack eutectic solder and any flux, I don't get cold joints. Even with unheated parts, the solder flows right in.
thanks guys!
I have always had some problems soldering...:ohgeez:
Ahhh
I have access to my dad's Weller WTCP iron (heat/magnetic switched)
The tips are coated, etc
STILL can't do joint to joint cleanly
What I would really want to see on video is someone experienced solder wires to a Cree led. Can someone please do this for the community?
Thanks!
AlexGT
You mean like this?
I'll try to take a vid with my crappy cam later. Others please do try it too.
One MAJOR thing not mentioned is that the new non-lead-containing solders have a noticably higher melting point. They are a good bit harder to use.
If you're new, use tin/lead solder and wash your hands before eating.
In the second video, he uses a pretty crummy weller iron. It's got an uncoated tip. These tips will oxidize QUICKLY (sometimes within minutes). They then require cleaning/tinning before they will work well.
On the other hand, weller makes a coated/plated tip. These are excellent. I have been using the same weller iron and original tip since about 1992. There have been many times that I forgot and left it turned on for several days just sitting there (out in the workshop). The tip never suffered any damage.
Lesson: use plated tips.
Video #3 at 6:11 shows what a coated tips looks like.
Also, soldering large wires (or anything large) takes a slightly different technique. Sometimes you need to tin (heat and apply a coating of solder) the objects. Let each cool down (to avoid overheating), then go for it.
I used to solder professionally for a living.....
We soldered anything from 30 gauge wire to multi strands of 000 (triple aught).
Wow Koala! That Cree soldering job is amazingly good! :wow::bow::bow::bow:
Please share how you do it.
AlexGT
Thanks for the tip! :)
Alright, firstly please turn off your speakers otherwise you will hear fan noise, me breathing and etc. Sorry I forgot to turn off the mic. I've added captions for each steps.
I am not a very good director, narrator nor a actor so please excuse the poor filming quality. I was sitting behind the camera it was an comfortable position and I couldn't solder normally. I did my best to show how to attach a wire to a Cree emitter. However, I don't think I did a good job.
In this video I used a slightly thicker(24AWG) wire. A smaller diameter wire than the solder pad will be ideal size. I used a 30AWG wire in the pictures I posted above, which is too thin for very high current.
http://www.youtube.com/watch?v=NSxmPGt353I
