TigerhawkT3
TVL1 is four Q2s in series, AAed to a block of aluminum with shallow fins, powered by a single 12V SLA.
TVL2 is nine Q2s in series, AAed to a block of aluminum with dense, deep fins, driven by an LM317T and powered by three 12V SLAs.
TVL3 is a single Q2, AAed to a piece of steel, superglued to a wood block, with 2AA alks on top for DD.
All these lights can be focused by those $1 optics from KD or DX (I forget which), and all have 1/4-20 mounting holes for use on standard tripods.
Now I'd like to begin development of the newest iteration, TVL4. It'll be smaller, more powerful, and have more features than TVL2. Here's what I have planned so far:
-Old CPU heatsink with room for nine stars, fan on the back
-Multiple white MC-Es in series
-Multiple red XR-Es in series
-White MC-Es will be mains powered, through the use of a variac, bridge rectifier, high-voltage capacitor, and bleeding resistors, with an LM138 driver
-Red XR-Es will be battery-powered, with an LM138 or LM317 driver
There are several things that I don't know, however:
-How much red will be filled in by the red XR-Es? What's a proper white/red emitter ratio, given equal drive current? I plan on being able to pot between not enough red and too much red (roughly :) ), so I need to know the "just right" value for that.
-What kind of connectors should I use? I was thinking of PowerPoles, but how about those connectors for automotive bulbs? I want something durable, low-resistance, DIYable, and maybe weather-resistant.
-I don't think there'll be enough room for optics, so I'm probably just going to use bare LEDs. Maybe I'll make some sort of white paper barn door assembly to fit over it. However, I would very much like to protect the bare LEDs. Maybe some sort of polycarb square bolted a few millimeters in front of the LEDs? If that, I was thinking machine screws that screw through the polycarb and into the heatsink, with nuts holding the polycarb in place.
That's pretty much all I can think of for now. Comments more than welcome.
