Hi Blades,
Thanks for your reply, another close one -- but not quite there -- from four sevens. It won't run 18650, which puts it out of the running right away. Otherwise, it's the xml2 that doesn't quite make it. A couple of years ago, those were competitive, but no reason to settle for 13k-ish cd today. Although I imagine the lights mentioned above from Olight, Fenix, and 4sevens (and Malkoff?) will get an xpl hi eventually. It's a race between whether they'll update their lights first, or if Nitecore, Klarus, or Eageltac will correct what seem like design deficiencies first...
It won't run a 18650, or its not recommended? I like my Smart Quark. The ability to set it from tactical, pro, to infinite is nice. I can add or subtract settings using the app. The LED race is frustrating. Each year there is one slightly better and I want it!! I really liked my MecArmy PT16 with three leds, but it has one side buton. The MecArmy SPX18's head is too big and it has a new fancy tailswitch. Not sure it will take 2 123a's.
From what I've seen, XPL HI lumens don't seem to be much different than those old XML2s. I have an old Thrunite TN12 (I think it is), a 1" 18650 XML2 light that put out 1000 lumens, a few years ago, which also seems to be in the general range of the XPL HI 1" 18650 lights, 800-1000 lumens. Besides, a 10% increase (or decrease, for that matter) in lumens is not really noticeable, so any marginal difference doesn't seem important to me.
What I"m after here is the increase in candlepower. That old TN12 was somewhere around 10kcd if I remember right. Meanwhile, Nitecore's P12GT is hitting 25kcd -- so, roughly double the candlepower. That's what the XPL HI brings to the table versus those older LEDs, and that I don't want to sacrifice. Even the noticeably smaller Eageltac DX30LC2 is getting 20kcd -- incredibly noticeable difference in beam intensity and throw, versus these XML2 lights, and that's what I"m not willing to give up.
What about a modder to swap in the new LED? I keep hearing about dedomed LED's -- not 100% sure what the benefit is, but I think more throw? Still reading.
Quick update: I emailed Eagletac to lay out my case for a rear switch that is suitable for a defensive use-case, they emailed me back promptly, promising to talk to their switch manufacturer to see what can be done. Will keep you all updated.
I've also emailed Klarus a month ago, pointing out that the XT2C XPL-HI is only reaching the candela levels that all other manufacturers can get with an XML2 in this size range. They told me that have good things coming.
I appreciate the response from customer service from both companies, and I'm hoping one or the other nails it. I haven't contacted Nitecore... I have a feeling that the switch delay is intrinsic to the design or engineering, and a bigger matter to fix than merely redesigning a reflector or switch
I've also not contacted Fenix or Olight... I figure XPL-HI offerings are just a matter of time
Going to go peruse Vinh's offerings...
Nice of them to answer so quickly.
I'll whip up a master list of what we have so far, but wanted to point out the ThruNite TN12 2016 ... It seems to hit all the requirements, except it's still using an XPL so limited to 13kcd. They update to a HI, with proper focusing, and they hit it
Also, for me this again shines a light on what an atrocious job Klarus did with their XPL HI XT2C... their competitors easily get 20kcd-ish (and sometimes quite a bit more than that) with an XPL HI with a light this size. Thrunite is getting essentially the same candela with a regular domed XPL as Klarus gets with a HI...
Waiting on master list...
I myself would have serious doubts about being able to manipulate a clicky switch under the high stress of a defensive situations. That's why LE and such tend to go with a simple tactical press for on non-clicky switch like the Z41. If you think you are gonna be able to only slightly depress a clicky for momentary when someone is trying to hurt or kill you, you are fooling yourself .
also clicky switches can and do fail. for a "tactical " light you really want a momentary on press/twist for constant on setup
could you really rely on a clicky switch that is used for lets say 6-10 years as an EDC then after 10 years and a few thousand clicks you need the light tactically 100% reliable .
I would rather give up some output and go with a Malkoff or Elzetta . or maybe an HDS light programmed to as close as you can to what you want?
if having the light be tactically 100% reliable is one of three most important factors then you will need to either compromise or rethink what you are looking for. I wouldn't truat anything short of a SF/Malkoff/elzetta switch
The reason I bought the Klarus XT2C was because of the switch. One for high, one for strobe. Easy to manulipate. I think TerraLUX has the same set-up(same manufacture?). I have my Smart Quark set up for high from tailswitch or side switch. Double tap either switch for strobe. Hold the side switch and starts in low and works its way to high.
Have you looked at the Armytek Partner C2 Pro v3 XHP35? I don't think it has enough CID: https://www.armytek.com/products/fl...tek-partner-c2-pro-v3-xhp35-white-silver.html
