DHart
A "3.7v" nominal Li-Ion is 4.2v right off the charger. Mine spend most of their lives between 4.2v - 3.8v, in my usage pattern. You get a longer useful life from Li-Ions if you top them off regularly rather than run them down to cut-off or (even worse) dead, especially on a regular basis.
If a long runtime is necessary, by all means, drive the M60 with a single 18650 and run it down until it dims significantly or is shut down by the PC. But no need nor benefit from doing that as a matter of course.
That's the nice thing with the M60... it's really versatile! You can drive it with 1 to 3 primaries, 2 rechargeables, or a single rechargeable (16340, 17500, 18500, 17670, 18650) and get good output from all. And you can get especially long runtimes with a single 18650. With the M30, you get an imperceptibly brighter output when compared to the M60 in single cell mode, but for a much shorter runtime. And you lose the ability to use more than a single cell. Both the M60 and the M30 are great lamp modules, but the M60 gives you a lot more options.
