southernson
- Joined
- Aug 4, 2014
- Messages
- 9
OK, my question may raise a few curious responses, so I'll give a short version for those who have an answer and don't need to know the reasons why, and a longer version for those who are intrigued.
Short Version:
I have 3 lights that all use the same battery type (18650). Only one of these lights are likely to be used (Main light). The other two lights will rarely be used (they are backups), but need to be ready to go at a moments notice.
Am I better off:
a) Top up the 'backup' light batteries every month or two, or
b) Rotating the batteries. (ie, 'top up' a cell from a backup, put it into the main light, and put the main light battery into a backup after charging after use, or?
c) If possible, use a AAA-18650 converter and use AAA batteries instead of a 18650 in the backup lights, (not sure these lights will take an adapter yet) or?
d) something else?
Longer Version
I'm a cave diver. We are required to have a primary light, as well as a minimum of 2 backup lights on all dives. My new lights are all LED's that use 18650, but my main light is push button with multiple modes, and I have 2 backup lights (different model) that are twist rotate (on/off only) that are less brighter. As such, there will always be one particular light (push button) used frequently, and the other two will be rarely used. (The backup lights).
I understand that rechargable batteries aren't designed to be charged, and then left in a light unused for any length of time, but that's exactly what is required for my backup lights. I need the backup lights to be reliable and 'ready to go', so I'm looking for options for this to work for me.
The options I have come up with are:
a) Every month or two 'top up' the backup light batteries. As I understand it from reading other posts here, li-ion's work on a cycle basis - so 'topping up' the batteries should use little of the cycle life. But then I also understand that li-ion's aren't designed to be stored for a long time unused at full charge, so I'm not sure about this.
b) Rotate the batteries. I figure the benefit for this is that each battery gets used and a good workout, plus I should know if a batter is going bad as I would find out whilst using it as my primary light and know it's time to replace it? It's a bit more of a pain to keep 'track' of the battery rotation though.
c) I've been told that AAA cartridges may fit my lights. If this is the case, I could use AAA batteries in my backup lights (after all, they're designed to be stored for much longer I believe)?
d) Is there something else I haven't considered?
To me, (c) seems to be the best approach but I don't know if this will work - so if it's not possible, should I be going (a), (b), or (d) - or is it much of a muchness and am I over thinking this. Considering that the backups could be the difference between life and death I'm wanting to make sure that I dot all my i's and cross all my t's.
Thanks in Advance...
Short Version:
Am I better off:
d) something else?
Longer Version
