KeyGrip
Wow, you folks are really zeroing in on the first responder market. I have a brother that might be interested in one of the vein lights.
omg! I received the 2x18650 FR1000A, got to use it at work last night.
The First Responder is impressive. :devil:
My coworker thought it was a lightsaber. He was somewhat
right(it does kinda look like one) had it around medium when
i turned it on..and he said wow that's bright. had to turn it up to max. lovecpf
nothing dangerous at work..my enemy is the dark server room.
dark no more.. :nana:
The high is obvisouly great..3.4 amps to a p7 rocks.
The low is seriously low and has almost no spill. Nice!
The square beam is interesting, but it actually makes sense. whatever
you point it at becomes lit up.. instead of shining a hotspot at someones
head...and possibly missing where/what their hands are doing..you
see the entire person equally with this beam from head to toe.
There are artifacts you see indoors...but theres so much light it opens
up the entire room anyway. outdoors it blends well.
the dial has a very natural output, there are no slow or fast spots..it's very
smooth. you can tell theres an oring in there..as you can feel the positive
resistance. spins around 300 degrees. easy to adjust with one hand while
holding the light.
both ends are delrin. the tail cap has a protective delrin cover that you can
pull out ~1/3inch and then the light tailstands...same with the night patrol.
you can fully slide it off for easy access to the switch. The front delrin bezel
appears to have a lip that serves as an accessory attatchment point.
looking beyond the fins, the actual head has a neat hourglass shape.
my camera is charging right now..so i'll post pics tonite. this is one heck of a
light. if i can get a break at work, i'll snap some outdoor shots against the
building and at some trees/cars...
the single 18650 body from the night patrol fits and works fine on the
FR1000A. brightness goes up to around 3/4...~2.2 amps im guessing from the
output.
The front bezel is a special urethane compound...
Curt
We will now call you Darth MWClint.
I heard the dial is now a little smaller than the original design.
Are you saving up for an Eiger?
Awaiting pictures from the cockpit of your Tie Fighter.....
Working on them now - hope to have some good ones soon.
Robyn
