Received mine, and like it fine. Kudos to download!
There was a big black spot in the center of the beam, and it was too pronounced for me to ignore. I tried a layer of screen saver on the lens but it was not enough. A layer of Scotch Magic Tape got rid of the spot.
The clicky is too stiff for me, but seems to be loosening up a little. It certainly will not get pressed in a pocket, and this light is a pocket light. End of gripes.
I like the interface, with hi-med-low and mode memory. It works fine as a twisty, too, just by backing off the tail cap. Threads are smooth and precise. It tail stands. There is a lanyard slot in the ring protecting the clicky. There is no brand name on the body anywhere. Mine is more a dark silver than the gold tint in download's photo. This is a very nice looking light.
The output, even with the diffuser layer on the lens, is great. It was a flood before the diffuser and is a floodier flood with the tape. I like a floody beam, but with the tape the spread is actually too much for even me. It's great for close up use, however. The output is so high that there is still enough throw for me, and in a pinch I could always just pull the tape off for more throw. The color temp is whiter than my Sabrewolf mini-EDC, so that puts it above 3500k, but it's not as white as the original SSC's. The color does not change much as you cycle through the high-med-low modes.
The head quickly gets hot on high, a testament to good heat sinking in an MC-E light this size. The body of the light gets warm but not too hot to hold. I will try to run a temperature series with a thermometer and see how hot it gets. My hand works fine as a heat sink on the body. I will be using it more on medium beam than high or low. I have not done any run times yet.
The size is fine for my jeans pocket, smaller than a drop-in. I plan to carry it in my pocket at night and when we are at our cabin. I am running it on an AW IMR 18650 cell, charged by a solar setup so the beam is stored sunlight.
Glad I bought this one. It will do me well until I find one with a slightly warmer beam and no black spot. I am not ready to change my signature line yet. I probably would have bought one of Sabrewolf's 18650's if he had offered this UI.
Again, thanks to download for a very nice light. :goodjob:
Randy
