MrAl
Hi again,
evan:
If you give me the dimensions i can tell you the approximate
inductance, but even a few microhenries or less can cause
oscillation. It's not a matter of how much inductance
is present, it's more about the circuit topology and
the switching speed of the components combined with
the inductance. With a small inductance, the only
difference is the circuit will oscillate at a higher
frequency than with a lower inductance.
Generally you dont want a linear circuit oscillating
if you can help it. Sometimes it doesnt matter but
if you can easily stop it you should.
Sometimes a circuit will oscillate about a given
operating point. In this case, it looks like it's
working normally until you look at the output wave,
which could be banging the LED with high current
pulses in order to achieve some average current level,
when it should be stable and at a nice, safe constant
current.
Newbie:
That's not a bad idea either, i'd try it that way
myself. It's a little easier to handle the wire.
Take care,
Al
evan:
current.
Newbie:
Take care,
Al
