If the smoke detector chirps when low like most due I don't see too much wrong with using nimh if it is in a high traffic area and you check it once or twice a month.
If the battery has 8 cells when it is nearly dead is probably will still put out around 8v so you may want to be careful not to overdischarge it. I often wonder why not make a smoke detector that uses 4AAA or AA instead.... would probably run for a long time I think I saw one that used 3AAA once but after getting a caller ID box that uses 3AAAs an having it blink change battery after 3 months I wonder if they used 5v parts.
