the "pulse jet" he shows is basically a tube that blows gasoline -- not all that complex, like the V-1 rockets.. I saw the one he talks about on that TV show Junkyard Wars; just a sheet metal tube basically, with gas and air blown in one end and the fumes blow out the other end, not exactly a mach-6 turbo-fan..
missile link :
As defined by the Intermediate-Range Nuclear Forces Treaty, a cruise missile is "an unmanned, self-propelled vehicle that sustains flight through the use of aerodynamic lift over most of its flight path, and such a missile may carry either a nuclear or conventional warhead (U.S. Weapon Systems 1). Figure 2 outlines the positioning of a typical cruise missileís components. Powered by turbofans, the cruise missileís mission is to deliver a high-explosive
bomb to a precise location. At launch, the TLAM-C/D includes a solid rocket booster that falls away once it has burned its fuel. The wings, tail fins, air inlet unfold, and the turbofan engine takes over. This engine weighs just 145 pounds (65 kg) and produces 600 pounds of thrust burning RJ4 fuel. The fuel load is 800 to 1,000 pounds (450 kg) of fuel at launch, or approximately 150 gallons (600 liters) (3). It is known for its incredible accuracy, due to the four guidance systems it incorporates. The Inertial Guidance System, TERCOM, DSMAC, and GPS (Block III variant only) systems enable the Tomahawk the ability to fly for 1,000 miles and hit a target the size of a single-car garage (3). The IGS is a standard acceleration-based system that can roughly keep track of the missileís location based on the accelerations it detects in the missile's motion. Once it is close to the target, the missile switches to a "terminal guidance system" to choose the point of impact (4). The point of impact can be pre-programmed by the GPS or TERCOM system. The DSMAC system uses a camera and an image correlator to find the target, and is especially useful if the target is moving. The two conventional warheads were previously mentioned in the ìDevelopmentî section in the Introduction. These are the conventional 1,000-pound high explosive and the 1,000-pound cluster bomblet warhead that showers a target with a rain of softball sized bombs (4). The bomblet version is designed to be deployed directly against "soft" targets such as people, trucks, buildings and light armored vehicles (Naval Warfare Journal 10).
