How will this driver behave if the Vin is below the Vf of the LED? Will it go into direct drive mode?
I guess I and others are probably a little disappointed that there is no switch mode driver available yet for the SST-90s. I for one want to use a 2S Li Ion pack or even 3S.
But I have a cunning plan. Use a LDO10C voltage regulator and set the output at 0.5v (+-) above the Vf of the LED and run that into this DIW's linear regulator. This will give a constant current regulator that you can run off any voltage up to 13.8v and yet still be fairly efficient.
Use some thermal feed back as well just for protection. Unsure if its best to use the thermal feed back on the CC driver or CV driver though.
Thoughts?
My $100+shipping is in for 2 of each. Can you explain what happens if using 2S LiIons?
Thanks
Hector
There were six models listed. I'm assuming you want two each of -1025 and -0512?
Using 2S LiIon would not inherently be a problem. The absolute max input voltage is 12V, and the max power dissipation is high enough. It's just that if you're only driving one LED, the efficiency would SUCK.
Eff = Vled/Vbat, so assuming 3.8V for the LED and 7.6V for the batts, you'd get an efficiency of 50%. The driver would happily do this for you if you can keep it cool, but it's going to generate even MORE heat than the LED (same amount of power, but the LED gets rid of some as light). The driver would be a little more forgiving of high temperature, but not a lot. So it's going to need as much heatsink as the LED.
With Packhorse's suggestion though, you could use that 2S LiIon pack, and probably keep the efficiency around 80%:thumbsup:
D
Thoughts?
Pack:
Are you referring to something like this?
http://www.eidusa.com/Electronics_Voltage_Regulator.htm
DIW, why not build it into your circuit, charge a bit more and save us some trouble for those who want LiIon? I'd be willing to pay a bit more.
Thanks
Hector
I'll take 2.
I'll PM my email for the data sheet draft.
I didn't include that because it's a LOT more complicated, and others are already working on it. I didn't see any need to compete with them. This was something easy that could hit the marketplace quick, without doing much damage to their sales.
This design literally took hours. With board layout, parts ordering, prototypes, datasheet, posts, etc, I might have 30-50 hours in the whole project. A well-done switchmode driver could be five or ten times that.
D
If possible change my order to 2 x IS1006-0820 8 2
Tanks,
I need a little help, where to install the pot? In series with H-C, and omit any connection to L-C? Or do I need to vary the value of R5 with pot?
Is this correct????
D
Thoughts?
