Thank you for this post.
That is very interesting. At first, I simply thought this was normal for
this type of HID bulb and design, but my Wolf Eyes 24W HID does not
have this issue.
And yes, I can clearly see the red tint even outside at night. Even on
green grass and trees.
Also, there is a rather large "peanut" shaped spot smack in the middle
of the hot spot. This is noticeable only on flat smooth surfaces (walls)
but at 6 meters to about 20 meters.
The beam not only has rings, a peanut middle, but its uneven, with
more red and violet color tinting on the right, and a pinkish tint on
the left. The hot spot it's self is kind of "egg shaped"!
In general, a very annoying light!!
I need to update this post.
I did sell my AE 24W, but I found that the artifacts I had mentioned
earlier had disappeared over time.
I believe it has to do with this bulb requiring a "breaking in" period.
As I used it, the "peanut" was the first to disappear, then, the red tint started to lessen and finely that disappeared too.
When I sold it, the beam looked fantastic!! and I almost changed my mind.
The new owner has not reported any of the earlier beam artifacts, and he
is very happy with the light.
If anyone is seeing the red tint, or other artifacts, I suggest you keep
using the light so the bulb can stabilize. Just use it for a few minutes
every day, like I did, and I think you will see a big improvement.
