The control side does seem rather unusual - 4 microswitches, each controlling a different driver, and with all power levels hardwired by the manufacturer.
Likely that's fairly cheap and reliable, but you'd think something looking as visually nice as this light would have something more flexible in terms of power control.
I'd tend to disagree with the manufacturer's statement:
This combination is excellent for caving, giving you a wide spread light and a very powerful spotlight at the same time!
If being forced to run the spread and spot together at the same power is 'excellent', I can only say that the Scurion-like alternative of being able to control them independently and mix them is rather better than excellent, and the only other alternative (independent control, but only of one beam at once) is still going to be better for
some users than having to have both on at the same power level.
A very powerful spotlight can often make a spread light look worse, rather than better, by providing a small patch of very bright light, making the surroundings look darker, and helping to burn out night vision.
Adding spread light to a bright spot certainly makes the spot less bad for general caving, but that's largely a reflection of how bad very powerful spot beams are for general caving - almost any change is an improvement.
Adding a little spot can sometimes improve a spread beam, but frequently the best mix is far from 1:1.
However, I suppose at some point, it may well be that some more sophisticated control is offered as an option.
