Re: AN/VSS-1(V)2 Searchlight
In Peak Beam Sys's
sale thread for the lights, Robert mentioned some would be held as spare parts cows. I wisecracked "how much for a spare lamp" and :bow: lotsalumens posted an
ebay link which I jumped on. It arrived today. I have been unable to find any info on servicing the internals of the searchlight so far. No clue as to the P/N for the lamp or its change procedure. The lamp came in a black cardboard tube with telescopic ends. The battered side label instructions, if followed would eliminate the possibility of some one touching it during replacement:
The upper end of the lamp has a pivoting , 2-finger bail that could permit it to be carried like an Osram lantern. :green: There are two large foam rubber rings that I assume are displaced for discard during lamp insertion. The arc gap looks to be 3/16-1/4"
The acceptance tag has a date of 3/3/64! It was made by the Hanovia Div. of Engelhard Industries in NJ. There is no outer glass UV shield, and if the voltage specs on the ebay post are correct, it is overdriven at the "stock" 28vdc!
(I suspect Mr TB is exhibiting some antisocial behaviour at this point. :green:
Larry
