jtr1962 said:Hence the reason why I'm now running my two BC-900s on a 2.8V power supply. See this thread.
jtr1962,
I believe you got the right idea. However, there is a slight problem. BC-900 uses a single output power supply. When you reduce the output voltage of the PSU, you are simultanesouly reducing the voltage to the MOSFET and the voltage to microcontroller.
The BC-900 uses a form of inexpensive mounting called Chip-On-Board (COB) to cut cost. If you've seen the guts of the charger, it is under the black epoxy. It is basically a silicon wafer without a case. These types of ICs are pretty sensitive to input voltage. Without knowing the exact specs, your supply voltage to the IC could be below the required voltage and may cause stability (latching) and reference voltage problems.
All the chargers we design almost always have a secondary voltage regulator (1% regulated output) right before the controller IC. However, I believe the BC-900 lacks this.
The best way would be to just reduce the voltage to the MOSFET but not to the main IC. I would imagine that, however, it is not an easy modification.
William
