I managed to find some batteries to do refresh and analyze.
Setup for NC Charger
4 AAA 750 mAh eneloops (less than 1 year old) taken from weighing machine. Found to be totally depleted to 0.2V.
Voltage recovered to 0.9V the next day except for 1 which reads 0.7V
All 4 batteries put into NC charger for refresh and analyze, 400mA charge and 200mA discharge.
Slot 4 contains the 0.7V battery.
Observations:
The readings for the int. resistance for the batteries read
Slot 1 265 mOhm
Slot 2 267 mOhm
Slot 3 269 mOhm
Slot 4 274 mOhm
[/URL][/IMG]
There was no change in int. resistance even after spinning the batteries in their holders.
I guessed I have 'ruined' the batteries by letting them over discharged.
As expected, slot 4 took longer to terminate as it has the highest resistance; about 10 minutes longer.
The batteries started discharging in about an hour, as per the manual.
Battery capacity at end of discharge:
Slot 1 684 mAh
Slot 2 734 mAh
Slot 3 712 mAh
Slot 4 697 mAh
Setup for C9000
4 AAA 750 mAh eneloops (less than 1 year old) taken from 2 remote controls
Voltage found to be about 1.28V each
All 4 batteries put into C9000 for refresh and analyze, 400mA charge and 200mA discharge.
Observations:
According to the C9000 manual, the battery should discharge after one hour of rest.
That did not happen. It took almost 2 hours before the batteries started to discharge.
In between the 2 hours, the voltage maintains at around 1.49V.
Slot 1 766 mAh
Slot 2 761 mAh
Slot 3 766 mAh
Slot 4 763 mAh
Observations between C9000 and NC charger
When the C9000 did not discharge after more than 1 hour, I took a few thermal images.
[/URL][/IMG]
Even though the charger say it is resting, it does not look like it is. The charger seems to be still 'on'.
Compared with thermal image of the NC charger, when it rests, the temp drops fast and the charger seems to be 'off'. The voltage dropped to around 1.42V compared with C9000 which maintains at 1.49V
As a side note, the day before, I did a quick measurement on the NC charger discharge of an AA battery
At 1A discharge, the pulse current was 1.25A
At 0.5A discharge, the pulse current was 1.25A
So it seems like the discharge current is 1.25A pulsed as compared with C9000 which IIRC, is 2A pulsed.
The thermal image shows the batteries in C9000 are hotter than the batteries in NC charger in discharge mode.
In fact, the temp profile for C9000 is higher in discharge mode than it is in charge mode.
However, in charge mode, the thermal image shows the batteries in NC charger are hotter than the batteries in C9000.
The NC charges at a pulsed 3A and IIRC, C9000 charges at 2A pulsed?
Conclusion
Strictly speaking, this exercise is a partial characterization than drawing of conclusions. I do not have sufficient knowledge to draw meaningful conclusions. There are pros and cons of each charger but one major feature that I like so far is the ability of the NC charger to display the internal resistance. Under normal usage, I do not monitor the voltages of the eneloops. I normally only charge them after a device gives a low battery warning or until a device no longer works due to low battery voltage. This can be seen by the over discharged batteries in two of the devices that I use. If indeed the over discharged batteries resulted in high resistance, then the ability to conveniently measure/display the int. resistance is useful in reminding me to be more conscious of monitoring and not allowing the batteries to go into an over discharged state. There's probably quite a bit more to do and go back and check/verify the condition of the high resistance batteries but I'll leave it for another day when time permits.
