TorchBoy
There is (or was) a guy a couple of blocks away who used to make his own mirrors, up to 36". He was so good at it he'd do the final tuning with a bit of rouge on his thumb.
I think he mentioned for the bigger ones just grinding out (angle grinder?) most of the glass to get the approximate shape. Most of them were F4, which I understand needs to be more precise than the longer focal lengths. Most people were :duh2: at his methods and and the results.Figuring with your thumb isn't too bad, but 36" is HUGE. You need a machine to do that: the thing is too heavy to grind by hand (unless you try to use a smaller tool on top, but then getting the shape you want is -- I don't know if anyone could do it except by machine. It would be hard to even lift a glass that size. Even 16" is really pushing it, working by hand.
But those mirrors are almost flat (F6 to F12, generally), and a flashlight reflector would need to be deep, with the focal point well inside of the curve.
Saying that a particular light is not practical without some qualifiers attached like "for me" is almost always a sure indicator that you have little knowledge about flashlights or how the human eye works.
As a matter of fact I have not. Try rereading it. When I speak about optics it is about the control of light. And no reflectors cannot match optics in that respect. There are other factors such as price and ease of assembly that come into play in the marketplace that make reflectors sensible.You've just done that haven't you...you've just written off anyone who prefers reflectors with no qualifiers attached.
There are more ways to accomplish this than I care to go into. It can be very easily done using optical elements before the main lens or by changing the surfaces of the main lens itself to manipulate the light to where you want it. A very simple way is to use a diffused lens like the ones I was making for the DEFT at one point. It has an intense center that blends out to the edge in a very buttery smooth fashion. It did not get a lot of attention because everyone here was so enamored with the smooth len's beam. Anyway that is a very simple way to accomplish it but there are more complicated and directed ways to do it.How about a dive light used in limited viz waters at night. You may want throw to cut through the limited viz but you still need some spill to see where you are going.
How can an aspheric do that?
I guess the cost of a better optic system is more than can be supported by general purpose flashlight usage.
