Renaissance Man
- Joined
- Dec 24, 2012
- Messages
- 7
Before going to chose a backpack one first needs to know what one will put inside. And that knowledge, oddly as it might sound, comes with experience. After a good deal of trial and error, buying and selling packs, I settled for three basic types that could be upgraded and modifined depending on the task at hand. The most used one is my urban EDC pack which currently is a Maxpedition Pigmy Falcon II. Contrary to previous opinions I would say that Maxpedition is not that bad on organization although other manufacturers may have neater solutions. The smaller compartments of the EDC pack would generally accomodate an organzer with some comfort items, a multitool, flashlight, pens -- the usual EDC loadout. The main compartment could either hold a laptop, training clothing, food or items that I would purchase somewhere along the way. The shortcoming of the Pigmy Falcon is that it doesn't have horizontal compression straps and belt. Otherwise it is very comfortable and versatile, love it. The near ideal pack of this sort seems to be the TAD Gear FAST Pack Litespeed. More volume, great ergonomics, compression straps and belt, more pockets and organizational capabilities and above all -- vertically elongated design which I found to be the most functional and comfortable for a light urban-style backpack. The shape of the pack is the factor of choice that I would stress above all.
For a mid-size backpack, what they call a "3-day pack", I have a Maxpedition Vulture II. Before buying a pack of this size (around 46 liters), I would recommend first trying it on and loading it if possible. The Vulture II has a belt but you cannot vary the position of the shoulder straps and it might just not fit you, especially if you are 180 cm and taller. If you want a rugger pack you can stick with the 1000D nylon, but that material also adds weght. I've heard that Kelty have some packs that could very well be just what is needed. Recenlty I ordered an Eberlestock Halftrack. It is a 50+ something liter pack, elongated again and has an inner frame which is important if you have to carry more weight= It is very ergonomic and has outstanding organizational capabilties.
If you need more capacity still, then external frame backpacks are to be taken in consideration, but that is not what is discussed here, I believe.
To wrap up, begin with what you would carry in the pack and stick with a vertically elongated shape that keeps the load closer to the body and doesn't stick back which will off-balance you and make you bend on the go. Hope that experience helps someone.
