nice on figuring out the low-volt hack.. i don't think it's important to 'eliminate' the spike, just reduction is fine.. and i personally don't often 'blink' my lights.. i'm more concerned about when it's been sitting over night and i turn it on.
newbie makes a good point about the sense resistor it will already be helping to limit in-rush.. i usually just measure mV drop across a wire somewhere to measure current.. for example in my bench supply i have a 40mohm resistance.. it's perfect for getting an accurate current measurement... just divide the mV drop by 40.
I actually ordered some of those opamp/comp combos they are cool.. i had a whole ckt designed around one of them, but re-designed it around one of the micrel LDO drivers.. i found a cheaper source for them.. they are 'double' the price i'd expect to pay for the opamp/comparator so i will probably build that ckt i described since it's already designed.. i'll be a buck 20 less to build.
to ans. the question about load.. this particular ckt is fine-tuned to the voltage it outputs.. you would need to tweak the base resistor
newbie has a very good point about the leakage through the zener.. i meant to mention that is likely a cause of biasing the voltage levels and perhaps why things don't read as you expected.
The beauty of this ckt is it is a buildable by anybody ckt.. you can wire discrete components right to each other in a bundle and fit into a light host. (of course heat-sink the FET to the body of the light somehow)..
I have the 'next generation' design lined up for full regulation in a simpler design than the one in my hotdriver.
For this simple soft starter.. one more mod that would maybe make it work better.. either using an active component to take place of the diode for helping discharge.. that will get you another 1/2V quicker drop.. and the other thought.. rather than clamping C1 with the zener.. clamp that whole ckt branch.... with a larger value zener.. actually i'm realizing that means you could eliminate R1, and replace with the appropriate zener.. so the 60k/4.7uF always gets the same voltage regardless of Vbat.. i guess that'd screw up the D1 discharge.. so we might have to work in that active discharge ckt.
It'll be a moot point for me n you.. the regulation ckt is not much more difficult to wire up and the regulator is $2.50, so for about $3.00 (or 7 if you want a really nice trimpot).. you can build a full regulator.
I'm working on re-designing the requlator to have the FET below the lamp like in this design.. it's tricky, but i think i solved the main problem (since the ground of the regulator is the drain on the FET it's regulationg!).. it needs a 'hack' to jump start.. once running it should stay running.. feels a little bit like perpetual motion.. hoping it won't oscillate.
I still have the 'ludicrously simple' ckt to build.. maybe Will can breadboard one of those... it uses only discrete components so just about anybody could hand-wire one on one of those neat prototyping boards avail. at RS.
here post in the thread with the final design.. can be built completely from discrete components. I think this is the ckt you want to play with next. You can scroll up on that thread to read the prequil... i can't remember what the value of the D1 is.. pay attention to the fact the ckt is 'upside down'.. Mr Al convereted it to nch fet for me and it was easier than re-drawing it.
Oh i could probably send you the DWL file i'm curious if they are cross-platform compatible anyhow.
Oh.. btw.. per usual i made a quick reference to this thread and that one..
http://softstart.rouse.com leads to this thread
http://ldo-simple.rouse.com leads to that other one.
http://hotdriver.rouse.com leads to the hotdriver
http://cpf.rouse.com leads to my flashlight collection of links
-awr
