petrev
Hi AWR
Re-Posted from wrong thread
is this the M6-Reg you are talking about
http://candlepowerforums.com/vb/showthread.php?t=101677
Are you going to be providing this as a mod or as a set of plans (final parts list and diags ) by any chance as it seems just the ticket - 2x3 17500 drop in holder with soft start.
Tried following the post but not being totally technical - just an average bodger - got a bit lost and cannot tell what stage you are at. Hope I'm not asking too many questions that have already been covered somewhere !
Thanks
Pete
You do seem to have spotted the big question with this board for an M6 !andrewwynn said:. . . (i.e. if the switch is 'on'.. can you interrupt power and will soft-start and such still work).
Thanks
Pete
andrewwynn said:you could build one into the tailcap simlar to how i'm building my M6 regulator.. if you build the battery pack with a solid threaded rod top to bottom it brings the 'pos' back to the tailcap.. you can wire from the 'pos' side of the batteries with a wire past the batteries back to get power to the tailcap.. Winny would have to answer if you can keep the 'switch' hard wired so that you can use the tailcap connection to operate the light (i.e. if the switch is 'on'.. can you interrupt power and will soft-start and such still work).
The soft start should solve the problem with protected cells.. I would work out a solution with 2x3 17500 like my M6x6 pack i made.
-awr
