Stereodude
FWIW, Coleman says not to run any of the lanterns indoor due to carbon monoxide worries.
I didn't see a low runtime rating for the Pinnacle on the Coleman website or in the manual. Where did you find it?Yes, that would be the Top Dog. I like the fact that it stores within it's self. The NorthStar IMO is a better value. You can get three more hours on low setting over the Pinnacle. I have found that running on highest setting for extended periods of time is seldom needed.
PinnacleOne 16.4 oz. Coleman® propane cylinder (sold separately) lasts up to 5.5 hours on high or 11 hours on low
They did not specifically say low setting. But the way manufacturers always take the highest specs they can promote to make a product look good I'm very certain this is at it's lowest setting. If this is fairly accurate then the low run time would be about double. The Pinnacle appears to be a nice light. If I was to add another it is what I would get. As to only having one I would probably go with NorthStar. Keep in mind I have no hands on with Pinnacle and am basing my opinion off what specs they have printed. If you have strong interest in the Pinnacle I would contact one of their reps directly to get details. If you do let me know the out come.Illumination lasts up to 5 hours on one 16.4oz Coleman® Propane cylinder
NorthStar Pinnacle They did not specifically say low setting. But the way manufacturers always take the highest specs they can promote to make a product look good I'm very certain this is at it's lowest setting. If this is fairly accurate then the low run time would be about double. The Pinnacle appears to be a nice light. If I was to add another it is what I would get. As to only having one I would probably go with NorthStar. Keep in mind I have no hands on with Pinnacle and am basing my opinion off what specs they have printed. If you have strong interest in the Pinnacle I would contact one of their reps directly to get details. If you do let me know the out come.
Quotes courtesy of Coleman's website.
Is the 5 hour runtime on high? How long does it run on low?I have a Pinnacle. What would you like to know?
Yeah, as Blacklight said...I believe the regular dualfuel is 1.3 pints, where the DF Powerhouse is deflinitely 2 pints (1 Qt).
Illum_the_nation, I had one of those, like 20 years ago....one problem was that when hanging, unless it was really damn cold out, the chain would get pretty hot. I guess it was because of the fact that the chains connections were right above the mantle, as opposed to more off to the sides. Also, that double-sided tied mantle was more prone to breaking about when jostled, such as hiking with it. I had to replace that ******* almost every weekend before giving up and hiking with the larger regular-globed lantern in my pack.
It still was nice because it was light and didn't take up much space; I just found it less reliable than the standard-globed 1-mantle. That and I burned the crap outta my hand about 10 times grabbing the chain without thinking.
The Coleman "PerfectFlow" line is the gas regulated ones, btw....just like a 123 cell, they drop out real quick right near the end. It's definitely noticeable, vs the old less-regulated stuff.
Seriously, I wish I could go back in time and find out who stole my regular old coleman 1-mantle propane lantern in college. That thing was the best. 8-10 hrs on a tank on full-burn, I had a flint aftermarket ignitor-sparker mounted on it, and a 6lb refillable propane tank with a 12" tree for week-long trips. Used it all through junior high, high school, and most of college. Probably 30-40 1lb tanks through it, and maybe 10-15 refills of the 6lb'er (which cost the same to refill as a disposeable 1lb'er!!! $2.50ish!!!).
