Thought I'd let people in the UK know that from Thursday Lidl will be selling rechargeable D cells, they are LSD I think, capacity is 4500mAh, the AA are 2100mAh and the C are 4000mAh, they are also doing AAA (850mAh) and 9V (200mAh)
Looking at a similar light to tk70, that requires D cell batteries...can you use the eneloops with the adapters or is this unsafe? not recommended? etc? new to this also...
You can use Eneloops with adaptors but their capacity is only 2000mAh which defeats the point of a D cell light.
Are Tenergy Centura D the best value?
In my experience all rechargeable nimhs settle out to around 1.3v after they have been off the charger for a certain amount of time. The time varies with each battery type and manufacturer lot.
I have some Eneloops (best nimh LSD) that were charged two days ago and they are still around 1.4v and may take a month to drop down to 1.3v but they will. The Blue Tenergy D cells aren't true 10,000mah cells or at least none of the ones I've tested have reached much over 8000mah. Tenergy Premium (white cells) are true 10,000mah cells so the internal chemistry is slightly different and they will measure different than the Blue cells.
I have run discharge test on both cells and the Tenergy Premium will have more capacity left after 6 months setting unused off the charger than the blue cells do fresh. I've verified this several times with several different batches of cells.
Keep in mind even with just a 2 or 3 amp load both cells will drop to 1.2v under that load so the static voltage doesn't tell you a whole lot about the cell.
In my testing the Tenergy Premium D cell is better than any other D cell on the market.
Hope that helps.
