Hey guys, I got my package on Friday, but had company all weekend, so I finally got to play with the Pacific this evening.
Let me say first that I very much appreciate getting to be a part of the beta testing and was very surprised to get all the available boddies and options, Thank You Peak Led Solutions and MJ.
I won't bother with shots comparing size as Don seemed to get all those taken care of quite well. If anyone wants a size comparison with anything I have, just ask.
I took a few quick pictures in my house as I didn't want to stand outside in the less than tropical 22 degree night. I didn't have a tripod, so some may be a little blurry, but it should give you a general idea of how the Pacific compares to my Carribean, L1P, Inova T3, Minimag w/nite-ize, and my Inova 2AAA Radiant with original led and with snow led.
I guess I should mention that the window blinds are about 22 feet away.
For some reason my camera didn't seem to pick up much of the spill on any of the Pacific pictures. It does put out a usefull amount of spill light, but I guess my camera didn't think so. I will need to check out the settings and so forth on my camera to maybe get better pictures, it was just on the auto setting.
Pacific 1AAA
http://img150.imageshack.us/my.php?image=pacific1aaa0za.jpg1
Again, it is deffinately not tunnel vision in the room, the spill does light the floor and you can very easily make your way around the room while holding the light straight forward.
Pacific 2AAA
http://img489.imageshack.us/my.php?image=pacific2aaa2mv.jpg
This answers the question of whether or not the 2AAA is brighter then 1AAA, yes. As others have said, it appears the electronics are quite intelligent.
Pacific 1AA
http://img489.imageshack.us/my.php?image=pacific1aa7sw.jpg
Odd that the light appears much whitter in the image than the AAA pictures, but they are actually quite similar to the eyes not near as dramatic as the picture shows.
Peak Carribean
http://img489.imageshack.us/my.php?image=peakcarribean1by.jpg
As soon as I took these shots, the carribean stared doing the famous pulsing as its falling out of regulation, so the battery was far from fresh. I need to get more CR123's when I buy a CR2.
Fenix L1P
http://img293.imageshack.us/my.php?image=fenixl1p0ys.jpg
This was taken with a brand new Rayovac. Obviously brighter and also whiter. I got lucky with the lottery on this one.
Inova T3
http://img293.imageshack.us/my.php?image=inovat33al.jpg
I never noticed it was kinda yellowish.
Minimag 2AA w/Nite-ize
http://img293.imageshack.us/my.php?image=2aamagniteize3fu.jpg
Easily beat by the 1AAA Pacific. In usage, the pacific seemed to have more spill light also but this may be an illusion due to the color difference.
Inova Radiant 2AAA
http://img154.imageshack.us/my.php?image=inova2aaaradiant2ce.jpg
Throughout writing this, I've come to assume that the camera doesn't pick up the yellowish spill light of the Pacific. Again the Pacific in all body styles is more usable than this light.
Inova Radiant 2AAA w/snow led
http://img154.imageshack.us/my.php?image=inova2aaaradiantsnow1ry.jpg
This was my experiment to get rid of the hideous blue in the stock light, that works, but got a little dimmer too. I use this light every night after lights out. The Pacific I believe will be a little too bright for this task. I may switch over due to the much brighter hot spot of the Pacific, I can see whether or not the doors are locked from further away, deffinately an advantage of the lux with good reflector over the 5mm with small reflector.
Overall:
My overall opinion on this new series from Peak is generally very positive. I'm a brightness kindof guys, so of course it could be a little brighter, but I'm sure I'll enjoy not having to change batteries very often.
The one thing I have found so far that I didn't like was mentioned by Don above, and its that the O-ring seems a little undersized. There is very little resistance to turn the light on or off. It doesn't matter which body is used, they are all loose, which says something for their good machining abilities. My Carribean is not like that at all, so I'm assuming this is not a normal characteristic of Peak lights.
As you can see in my pictures, the light output is a little on the yellow side. This doesn't present a problem to me as I don't notice unless I'm using two lights at once, and I don't find myself doing that. When in use by itself, to my colorblind eyes, it presents no problem.
Others have said the size is an issue for them, I don't mind the size since any light is too big for my keychain. I simply carry my lights in my pockets, I've never truely understood the keychain thing, oh well. With that in mind, the CR2 pocket body is about a half inch shorter than my Carribean pocket body and the diameter seems a little smaller too. Thats about a quarter of an inch shorter than a chap stick container or tube, whatever you want to call it, and only a little wider or thicker. I'm excited to see what kindof output it will have on a CR2.
Answers to questions:
Will the head fit on other light's bodies, I don't know about the lights you mentioned, but it is much too small to fit the carribean body.
As for the notches on the inside part of the head, I'm assuming that the outside protion of the head (when screwed into a body), will detach from the lower part of the head with the electronics and the reflector and lens will come out. MJ did mention something about a lens kit, so maybe this is how the lens is changed.
Battery life/checking Peaks' adevertised runtimes: I have not done any tests and since I have no way of measuring light output, I don't plan on it. I'll take their word for it.
The issue of weight has been raised and, yes the beta versions were made of brass, and yes they will be heavier than AL versions should be. If anyone wants, I can take the some parts or all to work and weigh them. My carribean is brass, so obviously I don't care much about the weight issue as long as it doesn't drag my pants down. I kindof like the feel of a heavier light, makes it feel more solid if that makes any sense. I also like the look of brass as it ages.
I do have one question though, is the momentary switch water proof, or does installing it on the light jepordize the water resistance. I don't have much use for it, but can deffinately see a use for someone who does a lot of quick inspections in computer boxes, junction boxes or other small dark places.
I hope this was helpful to at least one person. Again I appreciate getting to be a part of the beta testing and welcome any further questions.
tsi
