Brinkmann 3 Cell AAA Flashlight
jamesmustain
The Different Types Of Vacuum Cleaners: Best 2021 Buying Guide
Unfortunately, it's not uncommon for people to grow a deep resentment for their vacuum cleaner. You may have even experienced it all before: your vacuum's performance doesn't meet up with your expectations, it's too heavy, lacks maneuverability, fills up too quickly, breaks down or gets clogged too easily, so on and so forth.
Those are all signs that you have chosen the wrong type of vacuum to use.
Today's article will settle the "What is the best vacuum cleaner" question once and for all. Here are all of the popular types of vacuums that you would see on the market.
➻➻➻ Useful Link: Best vacuum cleaner brands
By Storage Type
The first is by storage type. In other words, how and where the vacuum would put all of the dirt and debris it picked up.
  • Bagged vacuums: These use disposable dust bags to store dirt and debris. Once full, you can detach the bag, throw it away, and replace it with a new one. More hygienic and easier to use, but replacement bags can be pretty expensive.
  • Bagless vacuums: Instead of dust bags, these use an integrated dust cup. When the cup is full, you have to empty it out, wash it, and put the cup back into the vacuum. No expensive replacements needed, but the emptying process is less hygienic and the cup requires labor-intensive cleaning and washing.
By Power Source
Modern top rated vacuums are powered by one of two methods: corded or cordless.
  • Corded vacuums: These use a standard power cord to feed electricity to the motor. Though it can provide uninterrupted, consistent power, the cleaning range of the vacuum is limited to the length of the power cord.
  • Cordless vacuums: A battery is used for power in place of a power cord. Cordless vacuums don't physically constrain you like corded ones do. However, you would still be restricted by the battery life.
By General Design
This is the part that most people are aware of since it's the most visually striking aspect of any vacuum model. In total, there are five different vacuum designs.
  • Upright Vacuums: This type is famed for its high cleaning power and wide cleaning path. This combination makes it especially popular for those who need to clean thick carpets often or deal with large, tough messes. Since it's the oldest type of vacuum cleaner, to some people, it's the best vacuum in the world just because of its familiarity. Nonetheless, be advised that uprights are notorious for being bulky and heavy. It's not uncommon for an upright to weigh north of 20 pounds.
  • Stick Vacuums: A stick vacuum is lighter, slimmer, and more maneuverable than an upright. Notably, modern stick vacuums typically have a 2-in-1 design, allowing you to convert the vacuum from its stick form to handheld quickly and easily. However, the average stick vacuum can produce less raw suction power than its upright counterpart.
  • Canister Vacuums: Canister vacuums are the middle-ground between high-performing uprights and maneuverable, flexible stick vacuums. Most of the components like the motor are packed inside of a wheeled canister, so you don't have to drag 10 - 15 pounds around the house all the time. They can still be a fair bit bulky, regardless. This type of top 10 vacuum cleaners also has a reputation for being costly to buy and maintain, too.
  • Handheld Vacuums: Handhelds are made to be as small and compact as possible. But keep in mind that its small size equals to a very modest performance level. It's good for small tasks and quick vacuuming sessions, but may not be good enough for whole-house cleaning.
  • Robot Vacuums: The most recent and modern type. This kind can vacuum the house all by itself, navigating the house using sensors on-board. But it's not perfect: it can't clean stairs and can occasionally get stuck inside of corners or underneath furniture. Robot vacuums are also more expensive on average than other kinds of vacuums.
Conclusion
We hope this short guide about the different types of top best vacuum cleaners has given you the answers you need to make an informed purchase decision!
