ChrisGarrett
30% loss that I mentioned is due to the fact of voltage mismatch between the solar panel and the battery, a problem with all PWM controllers. Unavoidable without going with a MPPT controller.
Actually, I just did a little research and I found out that with smaller arrays such as my 60 watter, a MPPT controller might actually be less efficient than a good PWM controller, due to the increased computer processing power and other transitor dohickeys found in many MPPT controllers! They take more power to operate, is the theory and that is power that's not going into the battery (batteries).
I do see the 17.5v>14.5 volt issue that you mention, but as one link pointed out, that's 14.5/17.5 = .83, so in that case, it's 17%, whereas MPPTs are upwards of 92-95% with larger arrays.
Anyhow, thanks for your posts, as I enjoy reading and learning about this stuff.
Chris
