I have been reading some old posts about lithium ion batteries and potential for exploding. The first one I read had to do with CR123...two in a flashlight,...and one popped, causing the other to pop, and the person ended up with some serious medical issues because of it.
Another was talking about not charging too fast or too slow....and stop right when the cycle completes. It seems that it is quite risky to have these cells for sure.
So it got me thinking. I have a charging station, a Nitecore Intellicharger i4 that plugs into the wall socket. I also have a Nitecore single bay charger that connects with a USB. Finally, I have a few rechargeable cells that have a mini-USB connection on the cell itself, and charges via USB.
Is the USB type charging system considered a good and safe way to charge?
How good is the Intellicharger i4?
Lastly, Olight uses the magnetic connection and USB to charge their lights. How safe is their mechanism? And are their single cell lights mostly safe to use?
Are lights with two 18650 cells problematic?
On a side note: I have a close to 80 mostly spent CR123 cells that no longer were able to power a flashlight. Or if they do, when the flashlight is raised to high, it will dim the output. Strange thing is, most of these cells still show 3V.
Does a place like Battery Junction take them? If not [or you don't know what that store is], what is the best way to get rid of them?
