The NLGI Consistency Number (a.k.a. Penetration) indicates the overall "hardness" of the grease. It is the distance a test cone sinks into the grease under controlled conditions. The number is expressed in units of 0.1 mm.I did a thread search and the only comparisons I came up with were for NyoGel 760G beling lighter viscosity and 779 being heavier. http://www.cpfreviews.com/Flashlight-Care-Nyogel-Lubricants.php agrees with that.
But it is completely at odds with Nye Lubricant's own overview page http://www.nyelubricants.com/products/nyogel.shtml. This says 760G is heavier and 779 is lighter. Lighthound also agrees with this.
Note that if you look at the NyoGel Spec sheets
http://productsearch.nyelubricants.com/pdf/TDS_English_NYOGEL 760G.pdf
http://productsearch.nyelubricants.com/pdf/TDS_English_NYOGEL 779.pdf
they only list the viscosity of the BASE OIL, and the 779 BASE OIL is thinner. But that is not the same as the viscosity of the grease as a whole. The latter would be much, much, MUCH higher than the base oil. The base oil would be an insignificant contributor. The grease is thickened with silica. Think "sand" (exceedingly fine grain).
So, once and for all, how about it? Which is the thicker grease, 760G or 779? Which one makes you work like hell to screw those threads, and which one is easier?
NYOGEL 779G Penetration Unworked 258 Worked 279
NYOGEL 760G Penetration Unworked 286 Worked 286
indicates 779G is slightly harder (258 vs. 286) in the Unworked state but virtually the same 279 vs. 286) as 760G in the Worked state. ("Worked" means the grease is squeezed back and forth through a perforated plunger like a potato masher before the cone test.)
This means threads lubricated with 779G might feel slightly stiffer after sitting unused for a while but will soften after repetitive movement.
