wquiles
The LED lamp unit does have a driver unit that connects to the LED unit itself. So there are basically 2 parts, one is the LED unit itself which consists of the 4 LED's wired in parallel and the other part is the driver to power it which has a label saying 8W 12 on it. But what i've been trying to do is under-drive the LED's because the original driver that comes with the LED unit makes the LED's too bright and they do warm up a little. I want them much dimmer. So thats why I bought a 280mA constant current driver.
So you are basically replacing the circuit that came with this kit with a different circuit? Do you know what current was being fed to the LED's with the original circuit?
Usually there is a small-value, current sense resistor, either inside the driver IC, or external to the driver IC. Each driver does this a little bit different, but they have a feedback loop in which they:How does the driver detect if it's parallel or series and give it either 3V or 12V? Just wondering my led's are in parallel and the driver should i'm assuming give no more than 4v max whereas if it was in series it should give 12v.
- measure current on that sense resistor - basically a voltage is generated as current goes through a known, high precision resistor (most of the time with a value less than 1ohm, like 0.1 to 0.01 ohms).
- if the current is still too low, it increases the voltage
- measure current again, keep adjusting the output voltage
- if the current is too high, lower the output voltage (there should be some hysteresis as well)
- etc.
Some drivers also have provisions for open circuit on the output, short circuit on the output, thermal overload, etc..
Will
