A casual observer--with such a low fvoltage, would these work good on 6 volt, if two XT-E's were used in series with direct drive?
7.6 volts is not easy or very practical, But 6v is--4 AA rechargeables, or one 4.5 amp hour agm. Naturally, one would like no more draw than 400 milliamps, for useful runtimes. Maybe xml is better for 6 volt? (I don't like efficiency drop of drivers; since, with dual led using 4AA direct drive, I could get 200 lumens at same current drive level that my Fenix hp20 uses for 130 lumen. Yes, current drops over time, but with variable resistor, you can lower resistance as time goes on--provided enough over head, but not too much that would pop the led on fresh cells.)
Then with price drop, it would be even more practical of a design.
