Drastically brighter, thanks for sharing!
I had some come in today. They're only about $2.50 which was a little less than the XP-E from the same supplier. I expected them to be priced closer to the XP-G.
Kind of hard to guess what is what without any text/labels. Can I assume that those are (from left to right):
XP-C -- XP-E -- XP-G -- XT-E ?
Is the surface mount foot print the same (interchangeable)?
Could you please light up the XTE a wee bit so we can see the shape.
Also, if you look carefully, the xt-e looks like it may be pointed a few degrees to right, while xp-e is to left. The xt-e shot has logs on right and spouting illuminated brightly, as is the center right foreground pot; while the xp-e has bushes off to left illuminated brightly, and so, the covered grill is a bit more lit up. Also, based on shadowing, the xp-e looks a tad lower in relation to the camera.
The 4th emitter in this lineup looks like a Cree XP-G Hi-CRI that I bought from LED-Tech.de a few months ago.
The XT-E is one of the good candidates for "no-heatsink" operation. When run with a dialed-down potentiometer on 2 NiMHs, the glow is pleasant. Mine hangs by 2 whisker wires I soldered to a bare sample XT-E. It's a good nightstand light to see my water glass.
