Don't know about anyone else, but I am tired of battery packs costing more than half of a light kit. This is the reason that I've never bought a decent lamp kit. I like building kits, but there are some realy nice kits with great features and controls out there.
Then I see the cost of replacement batteries. Ugh.
What I really want, more than anything, is an aluminum battery housing for loose batteries! Here's the skinny:
4x18650's
Cap at one end secures with a single bolt in the center (preferred)
Both caps tapped with four holes for standoffs for circuit boards
Cap at the other end... drilled for a cable gland (or two). Extra room under the circuit board for LED driver(s).
Two external taps on the side permit bagless mounting to bars/frame. Good airflow for housings serving as sinks for drivers. Maybe fin the cap at the LED driver (s) end for extra thermal capacity?
Pin or...? the caps so they are installed the same orientation after each battery swap.
Insets for rubber o-rings (cap seals)?
I can draw images this weekend if more detail on what I am thinking is needed.
A void in battery housings has always existed, I am surprised we have come this far, yet no one has stepped up. I just bought the Fenix BT20 because it allows use of loose 18650's. Finally, a non-chinagoods company is listening. There are two plastic housings available from the chinagoods sellers, one even has a thumbscrew cap, but it is 1s4p. I think most DIY's need 2s2p, 4s1p, 3s2p, etc. With one 4x18650 housing kit we can do four battery configurations (1s4p, 2s2p, 3s1p, 4s1p), by etching our own blank boards. And I'm sure someone would step up and provide pre-etched boards, pre-assembled boards, etc.
Thanks for consideration!
David
