Just ordered a DEFT-edc LR+ and I assume the dimensions are the same as the DEFT-edc LR which says that the body diameter is 25.08mm. I'm trying to track down a removable clip for this light so can you confirm that the diameter between the 2 grip rings on the DEFT-edc LR+ is 25.08mm? I'm also wondering if this light will take an AW 18650 IC 2900mAh or 3100mAh batteries. Thanks!
I don't know the diameter between the grip rings and I'm sure saabluster will chime in soon.
As far as the cells go I have read in another thread that saabluster prefers using Callies Kustoms 3100mAh cells.
They offer two sized cells in the 3100mAh size - 3100 w/pcb 1mm top apx measurements 18.7 x 68.8mm and 3100 w/pcb button top apx measurements 18.7 x 70mm. These cells are slightly larger than the AW cells you mentioned.
Both the AW 2900mAh and 3100mAh measure apx 18.52 x 68.16mm. These cells should work in the deft edc lr+ with no issues.
