lucca brassi
I have thought cooling LED in that way.....and I think it is something real different and effective
Hi, here's another idea
the mounting of the lamp to the goodman handle seems solid, but I see room for improvement on the handle itself.
Have a look at the design of the goodman handle of Big Blue:
http://www.bigblue.com.hk/tl-1x30w-led.html
Not sure if it can be seen very well in the pics, but the plate on which the lamp is mounted, can only move up and down, not twist around the bolts because there is some metal in front and behind the part that you hold in your hand. The slot is on that part and not in the part that is connected to the light head.
You can then also use the upper part of the slot to attach some bungee cord and/or a boltsnap for easy attachment to your BCD.
The only thing is as long as your led is on a piece of metal that is in contact with water it will do the job.
I do research for sorting machinery that uses laser, LED and camera technology for example to get the mice out of your frozen vegetable mixes:thumbsup: right on, machine vision is cool. Its amazing what you can acomplish when you give a computer eyes and a nice algorithm. What exactly do you do?
True ... but difference is in heat transfer cross-section of profile and length which brings us to volume and accumulation of heat .. and leds loves to work at very low temperatures .
( If don't work in these waters it is little difficult to explain and understand problem) But if you have ProE you can simulate heat transfer .
We use at our company I think Moldflow for tool construction of moulding plastics which is very similar at this problem (heatsource / sinks/ actual temperature)
oh, I hadn't seen the little edge. Should work fine I guess.
IMHO spiral cable is a definite NO NO NO !
Design is awesome, makes me want to break out my Alphacam cad/cam software again!
IMHO spiral cable is a definite no no!
A light like this would definitely be of interest to many who'd dive in confined spaces like wrecks and caves etc. Cave line, old cables in wrecks etc would slide off a single smooth cable but you having a chance of catching those items in the curly telephone cord like stuff is just one of many reasons why not do change the standard cable.
Really look forward to seeing this progress
Thats definately something I would like to see tested.
Probably would work very good, even with air in windy locations.
Pro-E handles the details pretty well for what you've posted.
Nice tech-drawings.
My two bobs worth... Looking at your design where the bezel screws onto the head, you have the threads and O rings round the wrong way.
The threads of the bezel will chew up the O rings before mating with their counterpart threads on the head. O rings need to go behind the threads, not in front.
Should be a nice torch when you're finished.
Hmmm..If you say so..., not interested in arguing so as long as you're aware of the situation then all is well.
OK disregard my previous comments..., Had another look at the diagram and see what you mean, 'sliding in from the front'. As long as those O rings don't peel off when you push in from the front I can see how that would work.
