DIY ceiling-bounce lightbar
idleprocess
decamped
After seeing mds82's work, I was inspired to do something similar - albeit on a more modest scale. My goal was to produce something better than the lame little Ikea LED lamp on the nightstand for occasional reading in bed and late night visits to the water closet. Having some previous experience with a ceiling-bounce light in the same room (out of commission because I decided that "PSU in a wall" was a bad plan and haven't gotten around to the centralized 12V DC bus I have in mind for another long-longering project), I know that it produces a nice, diffuse light.
I had in mind some bare aluminum channel running across the back of the bedroom some 6" below where the wall breaks at the vaulted ceiling. This would give some room to spread out the light that hits the ceiling and would also allow some light to bounce off of the wall paint to help warm it somewhat.
So off to Home Depot it was to discover some reasonably straight channel - 8' L x 1/2" T x 3/4" W. While they had some in stock that was reasonably straight and had few divots, it was also covered in mill and handling marks. Oh well - I've got sandpaper and steel wool. Think the Al channel was $11 a stick. Bought some wiremold and a flushmount switch for another $20 or so.
Next stop was a preferred local supplier - LED City USA. They stock a far wider variety of LED tape than their website suggests, including my favorite CCT (that's actually sold, that is) - 4000K. A 10' reel was $15 and I was only going to need about 7 feet.
Last stop was the local surplus electronics store - Tanner electronics - where I bought a 12V DC power supply and a 2.1mm jack for about $10.
I used some other consumable sundries I had about - 16 GA red/black hookup wire, a butt splice for the ground connection, some solder, electrical tape, and some wall anchors. Figure bill of materials amounted to $60. Tools and indirect materials needed were a soldering iron, 150 and 220 grit sandpaper, fine steel wool, a drill, various drill and driver bits, an icepick, paper towels for various cleanup, some rubbing alcohol, and porn star nitrile gloves.
Obligatory "coil of LED's" shot. I opted for "double density" 3528's, positioned between "standard density" (50% as many LED's per meter) and "high density" (200% as many LED's per meter)
First and most time-consuming step was finishing the aluminum. Aluminum barstock and channel from metal suppliers comes in rather unsightly condition. It has a fairly smooth surface that highlights random scratches, mill grime, handling marks, and anything that so much as gave it a hard glance. Since I have brushed-nickel fixtures in my house, I knew that giving the aluminum a distinct grain along its length would clean it up and make it blend with the other fixtures nicely. I probably spent 30 minutes working it with the 150 grit sandpaper to remove the major blemishes and smooth out the divots followed by 15 minutes working it with the 220 and then another 15 minutes with steel wool to complete the finish. The difference was night and day. While I didn't eradicate all imperfections, I did manage to make it look like a brushed nickel finish.
Of course, at this point I realized that I needed to drill some holes on once face to hang it on the wall. No problem - just offset from one edge by 6" then drill a hole every 12". Good thing I have a drill press otherwise they would have been a mess. Then I deburr the holes out of habit. Of course at this point the finish has taken some abuse so I work the l finish again with 220-grit and steel wool.
"So that's what the bar looks like hung up on the wall"
Getting to this point was ... interesting. I knew I needed to mark holes in the sheetrock and the preferable way is to use the piece I just cut so I can try to reasonably center them. I tried to stick the thing to the wall with liberal quantities of poster putty ... which failed since the overhanging mass liked to lever it away from the wall. So I took my chances and just marked my center line on the wall every 12". Naturally, some screws didn't align so well ... good thing I drilled more than I would need and it's pretty lightweight anyway.
The LED strip fabrication process was simple - cut to length, solder ~6' of wire to the end, wrap the solder joints with electrical tape.
At his point it was time to wrap up the work on the bar so I broke out the porn star nitrile gloves and scrubbed down the exterior aluminum to remove all the fingerprints and oil. I then swabbed the inside with alcohol and carefully applied the tape along the non-hole edge, centered up. Fastened it to the wall.
Testing prior to trimming out the wire
Lighting looks really good at this point. Just bright enough to read by directly under it. I like the effect of the clean ceiling bounce combined with the reflection off the brown wall paint.
End-on shot
Metal and wiremold detail
Should have trimmed the factory leads a bit ... and used less electrical tape.
The finished product
Not easy to make out, but the 2.1mm socket on the wall switch is inline (for use on a cable) rather than being panel-mount ... and has a cold solder joint (sigh). Perhaps that will be replaced someday - works fine so long as I don't bump it.
The view from below
The view from in bed
Camera really doesn't do the colors and perceived brightness quite right, but that's the nature of photographing light.
I'm satisfied with it.
poiihy
Uhm... in the last picture... What is with that hole or cut-out or whatever in the wall above the door? o_O That's some odd architecture...
idleprocess
decamped
It's a common feature of houses built in the region in the early 1990s which I've heard referred to as a plant shelf. Idea was to put plants or some other bric-a-brac up there to personalize your space. They're typically situated between the master bedroom and master bathroom. And yes, they're strange architectural quirks indeed - the overwhelming majority that I've see either go unused, sport plants that aren't tended to often enough, or feature bric-a-brac that's caked in dust... sort of like the typical suburban-house wet bar in a way only it's less costly to implement.
bandits1
If that shelf does indeed span the master bedroom to it's bathroom, doesn't that allow foul odors to drift into said bedroom? Not to mention steam.
poiihy
And also those with prying eyes who want to peek at you while you're taking a bath or doing something.... secret.
LOL
idleprocess
decamped
That it could. My sense of smell is far from "acute" so I don't notice any smells. Steam seems to be largely confined to the bathroom although I get some warning when the nearby smoke detector is near end-of-life when taking hot showers in the winter.
It's not the best design feature by a long shot, but I suck at doing sheetrock and am nearly as bad at painting, thus it remains. Maybe I'll do a decent looking filler panel on the bedroom side and something interesting on the bathroom side whenever I re-activate the ceiling-bounce lighting in there.
LOL
Most exciting thing that's happened in that regard was late one afternoon I hear the bedroom door slam shut. I investigate it thinking that perhaps the cat did it somehow, but can't find the cat. I think little of it - assuming the cat hid in the bedroom and also think little of the cat's absence when I turn out the light to go to sleep. About two minutes later I hear the cat mrowing urgently for assistance so I turn on the lights and spot the cat on said plant ledge - he presumably jumped up on the door then onto the ledge, simultaneously shutting the door.
poiihy
Also that light switch or just the cover next to the bathroom door there is tilted.
kingofwylietx
DFW, TX
I originally wrote:
I I'm curious about this project of yours, are the pictures still linked? I can't see them using IE or Chrome. I'm at work, so maybe the hosting site is blocked by our firewall.
Now that I'm home, I can see the pictures just fine, it must have been the firewall at work.
Poppy
Northern New Jersey
Nice job idle :)
Do you just run 12V DC to that LED strip?
Can you cut the strip to any length that you want?
I'd like to suggest that with the help of an assistant, it shouldn't be too challenging to snake your feed wire behind the sheet rock, being that it is an inside wall, and presumably not insulated. That would give it a cleaner appearance, but more permanent.
idleprocess
decamped
Nice job idle :)
LED strip is generally 12 or 24 V DC, cut to length.
The wall it's installed on is exterior, otherwise I would have run the wiring through the wall to a typical in wall switch and found some way to feed it DC voltage in a less conspicuous fashion.
Poppy
Northern New Jersey
Opps! Silly me, I was thinking that the light was on that partition wall with the flower pot opening. :rolleyes:
poiihy
Hmm, that might actually be a nice place for a light bar. Right on the ridge for the flower pots. It'll light both the bedroom and bathroom.
idleprocess
decamped
If you'll follow the link in post #6, you can read about that project. Out of commission because I decided that stuffing a 12V power supply down the wall was a bad plan.
kingofwylietx
DFW, TX
I bet you could run AC to a low profile transformer (to keep it hidden from below) for that light bar on the ledge. I didn't read that post, maybe you already addressed that option.
