DM51
Kier said:For those of you who have a draco already, is it easy to tell when you should be recharging the battery?
If the setting for the beam is high, then it is quite easy to tell when the battery is getting low – it visibly begins to fade, and when it starts doing that you should stop using it at once and recharge it. On a low setting this will NOT be easy to spot, as the current draw is less and the battery will continue to provide power even when it reaches a low safe limit.Kier said:I don't have a multimeter, and find it a bit ridiculous to have to check every day to make sure the battery is above 3V (or whatever it is).
Too bad the draco doesn't do something like blink when the voltage is too low. Anyways, back to my question: Is it easy to tell when the battery is low? I'll be wearing this around my neck and I'd like to not have any Li-Ion 'issues' in such a vulnerable position
The best thing is to recharge little but often. For example, if I use mine for only 3-4 minutes on high one night, I recharge it the next morning anyway. Even if it has only dropped to maybe 3.9v, I recharge it. Pull it from the nanocharger as soon as the light goes green and it will be below 4.2v. I hope to get 500+ cycles out of each cell, and I have 2 spare cells ($4.50 each, IIRC). The extra small charges aren't going to shorten their life, if anything they are going to extend it, 500 cycles = a long time, and $4.50 is pretty cheap for something that may last 2-3 years.
I would however very strongly recommend you should get a multimeter. You can get reasonably-priced ones, and you will then be able to monitor your cells properly. When you get one, make sure you test it for accuracy against a professional-grade one like a Fluke, as even a 0.1v difference is quite a lot when you are dealing with Li-Ions.
Re the other question above concerning sapphire lenses, I asked Jonathan about this some time ago, and he said they are very tough and he's never heard of one that size breaking, so you may decide you don't need a spare.
