I have performed one or two searches on the web for a driver capable of producing the necessary current for this led. The trick is to use the word led in the search, so that it narrows down the results to low voltage units. I hope you are not expecting anything that will fit in a normal sized flashlight, such as a maglite. You will only find large block style assembly's that will need to be mounted to something. Good luck finding with pwm dimming. I would like to see your build when you get this led blazing at 20 amps or more.
