Gazoo: Thanks for your comment. Don't worry mate, you'll get there one day. I had so much fun building mine and I'm sure you would too . In regards to PBS cube, there's a group buy going on over at photonlexicon forum for good quality PBS cubes centered at 633nm and 473nm for $30 a piece. I'm not sure if they are going to take new order though. Just drop by and ask if you're interested. I hope you are not too late to order some.
IgorT: Very good explanation you got there mate :twothumbs. In regards to TEC, I think you kind of misunderstood on their power requirement. TECs are voltage dependent components. Of course you can limit their current to give you variable cooling/heating power, but they will always consume current roughly around what the data sheet state at their rated voltage no matter how much current you supply to them (I use 30A PSU for mine and they only consume about 16A, which is within spec). Giving higher voltage than the rated input could also damage the TEC elements permanently. Lower voltage than the rated spec will results in the TEC consuming less current, hence voltage dependent. With diodes you can feed them 5V even though they're actually rated at 3V. They will eat 3V in the end, but you have to pay great attention to their current requirement since they're current dependent. TECs are similar to light bulbs whereas diodes are exactly the opposite when it comes to power requirement. I hope you understand what I'm trying to say :naughty:.
PS: I just would like to remind you all that open can diodes from Pioneer 112D and Sony 16x drives are the only diodes that I know capable of withstanding current greater than 300mA when properly heatsinked. All the other diodes that I've tried just died sooner or later at this current and I don't know about the others since I haven't tried them all. Right now I'm just using diodes from Pioneer 112D as they yield spectacular results based on my findings.
Cheers guys.
Cheers guys.
