As I have no idea what the specs of my red 'gem' are, I'm reluctant to run it much higher than 150mA. Even at that current, using a lens and a body from a $1 key-chain pointer, it is able to ignite matches in a second and punch a hole through a black floppy disk at a distance of 10 cm in less than a minute with a well focused beam.
A well-desined ARC lens will yield even more power and focusing precision. Some of those chinese cheapos never quite managed to focus in a well-defined spot without many side artefacts... A good source is Roithner, Austria. They ship collimator lenses in any quantity.
You seem to know A LOT about electronics in general and the lasers as well. I would just like to point out one thing... We call the laser diodes "LDs", so as not to mix them up with LEDs.. LED is Light Emmiting Diode, while LD is a Laser Diode.. I'm sure you already know all that, so please don't take this wrong. I just pointed it out, cos it could be confusing to a newbie..
Igor, I saw the photo of your 'blaster' and I noticed that the beam aperture is somewhat narrow. I used a similar set-up for my experiments and I discovered that the 'burning efficiency' increased when I increased the diameter of the aperture on the focusing nut. Pehaps a small circular aperture makes the projection more dot-like, as opposed to the 'bar-like' spot produced by most low-power leds...however this may effectively prevent some of the 'burning power' from escaping the aperture.
Thank you! I was also considering this as a cause of the problem (hole too small in diameter to allow all the light to get out)
I will make the hole bigger, since i have to mod that thing anyway. I messed up my calculations (distance between the LD and the lense).
This means i also have to make an indentation in the inside of the focusing nut, to be able to screw it in further and allow for better focusing.
I'll also make the hole bigger now. Thanks for the hint!
BTW: Do you think this too small hole could also be the cause of the lines going away from the point on the wall (in my pic above)? Like reflections from the edges of the inside of the too small hole, for example? Well, i'll know for sure in a few minutes anyway...
I will soon be buying a 20x LG drive. Wonder what the LEDs are going to be like. I am beginning to want a closed-can specimen for the sake of reliability. Open-can leds may dissipate heat better, but are susceptible to mechanical damage and environmental contaminants...
My goal now is to find good lenses. I bought all key-chain lasers in my town and only one or two had satisfactory lenses without much scratches and other frightening optical defects......
Since my lense assembly is also from a cheap laser pointer, i'm afraid, this is the cause of many of my problems..
I just hope the AixiZ modules arrive soon.
