Also FWIW, discussion of PWM is pointless without knowing the frequency. I know some are over 1kHz, which should be imperceptible.
I don't really care abou PWM or non-PWM. I care about perceptible strobing when looking at say, a fan, or waving fingers. I care about perceptible tint shift. I care about runtime compared to similar available lights.
Those are all things that are potentially affected by PWM, but let's discuss those as they affect this specific light rather than the religious arguments about PWM itself.
Incidentally, for the "movies are 24Hz" guy, you are so wrong about how the eye works it's hard to know where to begin. Firstly, the lowest frame rate required to consistently give the illusion of motion is 12fps not 24 (even lower in special cases), which is why old Disney cartoons are 12fps. But that's not the same thing as making flicker imperceptible. It's pretty easy to see flicker on a low-persistence display up to about 100Hz, especially in peripheral vision. I forget the actual figures but the eye can detect motion at a "frame rate" over 1,000Hz. However, the eye does not actually have a frame rate so that figure while illustrative, is sort of meaningless.
I have a particular dog in this race in that I get migraines and these can be brought on by flickering lights, including fluorescent tubes (50Hz here in the UK) and older computer monitors. I used to always check if a CRT monitor had perceptible flicker by looking at it indirectly. I could easily see it strobing up to about 90Hz and this only became imperceptible at 120Hz. Frequency in Hz doesn't tell the full story either: not every strobe is a perfect square wave with equal positive and negative phase. You don't get this problem with LCDs because they are high-persistence, so they don't flicker, even with a lower refresh rate (typically 60Hz). Older LCDs had a big problem with "ghosting" because of this. It's still noticeable at times, like if you scroll a web page really fast.
So, unlike most people here, I have a good reason to dislike PWM. And yet, given that exposure times tend to be quite short and total lumens relatively low, I really don't care about it very much at all.
