Begin quote from SelfBuilt's review:
"Potential Issues
As with other Eagletac models where output mode is set by the degree the head is tightened, you need to keep all contact surfaces in the head scrupulously clean. Long-term reliability of the switching mechanism/pins is unknown."
end quote -----------------
My failure report of a GX25A3 switching/pin system is based on a single sample. Hence, a datapoint of 1, degrees of freedom 0, so nothing can be concluded except that my copy of this light had a switching failure. The head-twisting switching system relies on 3 spring-loaded pins to maintain contact with the dual rings. In this single case, one of the spring-loaded pins developed a weakness in the spring such that the pin no longer contacted anything. The light remained mostly in low mode. I tried pushing on the pins to determine if maybe I could 'pop out' that pin. no luck.
At the same time I purchased the SX25L3 MT-P0 model which uses the same switching mechanics of 3 pins. However these pins are thicker in diameter which gives more room for a more robust spring. So far no problems.
Nevertheless, the head-rotation to change the light levels also rotates the on/off switch. That really messes up my handhold. I gave up and returned the GX25A3 for credit. I decided to retain the SX25L3 primarily because of the impressive output from a single LED and to see if I could get used to that switching mechanism. eh, still not a desirable method to switch levels.
