I will, just haven't made it out yet. Hope to do it over the next few weeks.you will post any outdoor beamshots?
I have this light. The only complain I have is that in the dark, it's hard to locate the on/off button. I solved that by sticking a small piece of luminous sticker on it. But only last 1/2 hour or so. I think the nitecore method of having the button lighted up is a great idea that eagle tac should adapt for those light with side buttons.
Selfbuilt, btw, you should indicate that those who did not buy the kit won't be able to use the accessories on their basic set like mine.. Anyway, my basic set did not feel like a diffuser is useful but the end cap switch would be!
Low warning light is good and nice to have.
I could not agree more. I am waiting to see what Nitecore brings to the table using this emitter. No low voltage warning light makes me continue the search...
The extra tailswitch is electronic, with similar feel to the main side switch (I know from my GX25A3/SX25A6 reviews).Right now I'm trying to decide if the Kit version is worth the markup. Do you know if the extra tailswitch is electronic or a physical clicky? Hoping to see some beamshots of the white diffuser versus undiffused, too.
Understandable. Thanks for the heads up on your flip-up diffuser solution--I like it.The extra tailswitch is electronic, with similar feel to the main side switch (I know from my GX25A3/SX25A6 reviews).
Sorry, I don't plan to do diffuser beamshots (hard to capture well on a camera). But it helps at all, the Blizzard Creek see-through scope cover #7 (1.8-1.89") fits (although it is a tight fit). You could add diffuser film, and make it into an impromptu flip-top diffuser. I've described the process in this post, for a smaller light.
Thank you for the fantastic review. Ive had tons of lights over the years, maybe 1 or 2 of my lights have been where you loosen the head to change levels or modes. Looking at your pictures I can't see how the head maintains its IPX8 integrity if the head is moved from a seated position. I guess it all depends on where the seal is located on the body.
Had my mind set on a DDR30 for build and quality. Looked at the TK75 for retro look and value. But never even thought of the SX25L3 MT-G2 for me, based on some photo's it has a wall of light illuminating out to the sides, great for search/walking . Hope the build quality is as good as jetbeams, I plan on placing an order for the SX25L3 MT-G2 Kit version. Great review. (Seems like nobody has this light in stock)
That's because IPX8 makes no claim about using the light under water. Typically, testing is done with the light off the whole time.Thank you for the fantastic review. Ive had tons of lights over the years, maybe 1 or 2 of my lights have been where you loosen the head to change levels or modes. Looking at your pictures I can't see how the head maintains its IPX8 integrity if the head is moved from a seated position. I guess it all depends on where the seal is located on the body.)
221 days no good?I'm measuring 640 micro amps standby drain on mine (mt-g2 version, non-kit) which equates to 221 days with 3400mAh batteries. Not good
